frictional pressure drop in rhoPisoFoam (using fanning friction factor)
Old   July 18, 2018, 22:09
Default frictional pressure drop in rhoPisoFoam (using fanning friction factor)
Ashish Kumar
ashish.svm is on a distinguished road
I want to include frictional pressure drop calculation in rhoPisoFoam.
frictional pressure drop can be calculated by 0.5*ff*rho*U^2
where ff is fanning friction factor, which can be calculated by using standard correlations based on reynolds number.
I have modified UEqn as following.
fvVectorMatrix UEqn
    fvm::ddt(rho, U)
  + fvm::div(phi, U)
if(includeFrictionFactor)
  UEqn += fvm::div(phiFrictional, U);
phiFrictional is calculated as following.
phiFrictional =
    fvc::interpolate(fanningFrictionFactor)*
        (fvc::interpolate(U) & mesh.Sf())
      + fvc::ddtPhiCorr(rUA, rho, U, phiFrictional)
and added the following term in pressure equation
      pEqn += fvc::div(phiFrictional);
but using this formulation leads to incorrect results.
Please let me know what is wrong in my formulation.
Or
Please suggest me some other solver which has the pressure drop calculation using fanning friction factor.
ashish.svm is offline   Reply With Quote
Old   July 19, 2018, 07:22
Santiago Lopez Castano
Santiago is on a distinguished road
fvVectorMatrix UEqn
    fvm::ddt(rho, U)
  + fvm::div(phi, U)
phiFrictional =
Or
Its wrong, the velocity in your formula is the square of the magnitude of the velocity, or inner product. Besides, why you take the divergence of such force?
Santiago is offline   Reply With Quote
Old   July 19, 2018, 12:28
Ashish Kumar
Sorry, my understanding of the friction factor was wrong. I found out that this force is applied to the wetted surface.
But I am unable to understand how to modify the momentum equation to include fanning friction term.
caculation of friction factor Dilip Main CFD Forum 9 February 23, 2016 06:00
Pressure drop using Fan type BC Alexis Sack OpenFOAM Running, Solving & CFD 2 September 22, 2014 10:18
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Pressure drop in a heat exchanger Diana FLUENT 5 December 13, 2007 10:33
Pressure drop of valve with valve opening of 30% elogesh Main CFD Forum 2 January 5, 2007 13:30
