Weird fluid distribution in the interMixingFoam simulation
Old   July 11, 2018, 10:55
Default Weird fluid distribution in the interMixingFoam simulation
Pei Li
HectorLee is on a distinguished road
Hi, everyone,
I am trying to use interMixingFoam to simulation the interactions between immiscible and miscible fluids in a capillary tube. The simulation domain is a 12mm-long and 2mm-wide capillary tube and the initial condition in x-axis is: air occupies the space from 0mm to 1mm; 'other' fluid occupies the space from 1mm to 2mm and the left part of the tube is water. Then the constant velocity boundary is applied to the left side of the tube and the right side is zero gradient boundary.
In the first 4s, the distribution of 'other' fluid and water is fine as the first figure. However, after that, water starts to appear around the interface between air and 'other' as the second figure, which violates physics law apparently.
(Somehow, I can't upload the figures here, so there are the links for the figures shared in the dropbox:
At t = 4s: https://www.dropbox.com/s/zpao05jgef...%3D4s.png?dl=0
At t = 8s:
https://www.dropbox.com/s/eb8hmuzh02...%3D8s.png?dl=0
Is there anyone knowing what causes this strange phenomenon and reasons?
Thanks a lot!
HectorLee is offline   Reply With Quote
Issue in simulation of open channel flow with high viscosity fluid soleymm1 STAR-CCM+ 2 December 3, 2017 02:44
T-Junction using rhoPimpleFoam (Simulation blows and weird result) mecbe2002 OpenFOAM Running, Solving & CFD 4 July 23, 2015 16:26
Query regarding temperature distribution in Solidworks flow simulation syarif FloEFD, FloWorks & FloTHERM 3 February 27, 2013 06:22
Heat transfer simulation of Gel(high viscous fluid) on a solid plate fshak92 STAR-CCM+ 0 October 26, 2012 13:42
Numercial Simulation on Contaminant Distribution Apple L S Chan Main CFD Forum 4 October 24, 2011 08:01
