July 11, 2018, 09:26 |
CubeRootVol in IDDES for interFoam
Christian Jähnel
Rep Power: 10 |
Hi Foamers,
I have a problem with IDDES in interFoam. Since I moved to OF5.0 I get this error: Code:
Attempt to cast type cubeRootVol to type IDDESDelta From function To &Foam::refCast(From &) [with To = Foam::LESModels::IDDESDelta, From = Foam::LESdelta] in file /sw/taurus/applications/OpenFOAM/OpenFOAM-5.0/src/OpenFOAM/lnInclude/typeInfo.H at line 114. This is the Outputfile: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 5.0 Exec : /sw/taurus/applications/OpenFOAM/OpenFOAM-5.0/platforms/linux64IccDPInt32Opt/bin/interFoam -parallel Date : Jul 11 2018 Time : 12:40:28 Host : "taurusi6340.taurus.hrsk.tu-dresden.de" PID : 29205 I/O : uncollated Case : /lustre/scratch2/s2665038/DMF_LES nProcs : 24 Slaves : 23 ( "taurusi6340.taurus.hrsk.tu-dresden.de.29206" "taurusi6340.taurus.hrsk.tu-dresden.de.29207" "taurusi6340.taurus.hrsk.tu-dresden.de.29208" "taurusi6340.taurus.hrsk.tu-dresden.de.29209" "taurusi6340.taurus.hrsk.tu-dresden.de.29210" "taurusi6340.taurus.hrsk.tu-dresden.de.29211" "taurusi6340.taurus.hrsk.tu-dresden.de.29212" "taurusi6340.taurus.hrsk.tu-dresden.de.29213" "taurusi6340.taurus.hrsk.tu-dresden.de.29214" "taurusi6340.taurus.hrsk.tu-dresden.de.29215" "taurusi6340.taurus.hrsk.tu-dresden.de.29216" "taurusi6340.taurus.hrsk.tu-dresden.de.29217" "taurusi6340.taurus.hrsk.tu-dresden.de.29218" "taurusi6340.taurus.hrsk.tu-dresden.de.29219" "taurusi6340.taurus.hrsk.tu-dresden.de.29220" "taurusi6340.taurus.hrsk.tu-dresden.de.29221" "taurusi6340.taurus.hrsk.tu-dresden.de.29222" "taurusi6340.taurus.hrsk.tu-dresden.de.29223" "taurusi6340.taurus.hrsk.tu-dresden.de.29224" "taurusi6340.taurus.hrsk.tu-dresden.de.29225" "taurusi6340.taurus.hrsk.tu-dresden.de.29226" "taurusi6340.taurus.hrsk.tu-dresden.de.29227" "taurusi6340.taurus.hrsk.tu-dresden.de.29228" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: Operating solver in PISO mode Reading field p_rgh Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type LES Selecting LES turbulence model SpalartAllmarasIDDES Selecting LES delta type cubeRootVol Selecting patchDistMethod meshWave LES { LESModel SpalartAllmarasIDDES; delta cubeRootVol; printCoeffs on; turbulence on; laminarCoeffs { } oneEqEddyCoeffs { ck 0.07; ce 1.05; } dynOneEqEddyCoeffs { ce 1.05; filter simple; } locDynOneEqEddyCoeffs { ce 1.05; filter simple; } SmagorinskyCoeffs { ce 1.05; ck 0.07; } Smagorinsky2Coeffs { ce 1.05; ck 0.07; cD2 0.02; } spectEddyViscCoeffs { ce 1.05; cB 8.22; cK1 0.83; cK2 1.03; cK3 4.75; cK4 2.55; } dynSmagorinskyCoeffs { ce 1.05; filter simple; } mixedSmagorinskyCoeffs { ce 1.05; ck 0.07; filter simple; } dynMixedSmagorinskyCoeffs { ce 1.05; filter simple; } LRRDiffStressCoeffs { ce 1.05; ck 0.09; c1 1.8; c2 0.6; } DeardorffDiffStressCoeffs { ce 1.05; ck 0.09; cm 4.13; } SpalartAllmarasIDDESCoeffs { delta IDDESDelta; IDDESDeltaCoeffs { deltaCoeff 1; cw 0.15; } } IDDESDeltaCoeffs { cw 0.15; deltaCoeff 1; } cubeRootVolCoeffs { deltaCoeff 1; } PrandtlCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } Cdelta 0.158; } vanDriestCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } Aplus 26; Cdelta 0.158; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } kappa 0.4187; wallFunctionCoeffs { E 9; } Ce 1.048; sigmaNut 0.66666; Cb1 0.1355; Cb2 0.622; Cw2 0.3; Cw3 2; Cv1 7.1; Cs 0.3; CDES 0.65; ck 0.07; } The same error occurs for other delta versions. Here are my turbulence Properties: Code:
simulationType LES; LES { LESModel SpalartAllmarasIDDES; delta cubeRootVol; printCoeffs on; turbulence on; laminarCoeffs { } oneEqEddyCoeffs { ck 0.07; ce 1.05; } dynOneEqEddyCoeffs { ce 1.05; filter simple; } locDynOneEqEddyCoeffs { ce 1.05; filter simple; } SmagorinskyCoeffs { ce 1.05; ck 0.07; } Smagorinsky2Coeffs { ce 1.05; ck 0.07; cD2 0.02; } spectEddyViscCoeffs { ce 1.05; cB 8.22; cK1 0.83; cK2 1.03; cK3 4.75; cK4 2.55; } dynSmagorinskyCoeffs { ce 1.05; filter simple; } mixedSmagorinskyCoeffs { ce 1.05; ck 0.07; filter simple; } dynMixedSmagorinskyCoeffs { ce 1.05; filter simple; } LRRDiffStressCoeffs { ce 1.05; ck 0.09; c1 1.8; c2 0.6; } DeardorffDiffStressCoeffs { ce 1.05; ck 0.09; cm 4.13; } SpalartAllmarasIDDESCoeffs { delta IDDESDelta; IDDESDeltaCoeffs { deltaCoeff 1;// 1; 2 fuer hexMesh ? cw 0.15; } } IDDESDeltaCoeffs { cw 0.15; deltaCoeff 1;// 1; 2 fuer hexMesh ? } cubeRootVolCoeffs { deltaCoeff 1;// 1; 2 fuer hexMesh ? } PrandtlCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } Cdelta 0.158; } vanDriestCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } Aplus 26; Cdelta 0.158; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } kappa 0.4187; wallFunctionCoeffs { E 9; } } Code:
ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { default none; div(rhoPhi,U) Gauss linearUpwind grad(U); div(phi,alpha) Gauss vanLeer; div(phirb,alpha) Gauss linear; "div\(phi,(k|omega)\)" Gauss upwind; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } Code:
solvers { "alpha.water.*" { nAlphaCorr 1; nAlphaSubCycles 1; cAlpha 1; MULESCorr yes; nLimiterIter 3; solver smoothSolver; smoother symGaussSeidel; tolerance 1e-8; relTol 0; } "pcorr.*" { solver PCG; preconditioner { preconditioner GAMG; tolerance 1e-5; relTol 0; smoother GaussSeidel; } tolerance 1e-5; relTol 0; maxIter 50; } p_rgh { solver GAMG; tolerance 5e-9; relTol 0.01; smoother GaussSeidel; maxIter 50; }; p_rghFinal { $p_rgh; tolerance 5e-9; relTol 0; } "(U|k|omega).*" { solver smoothSolver; smoother symGaussSeidel; nSweeps 1; tolerance 1e-6; relTol 0.1; }; } PIMPLE { momentumPredictor no; nCorrectors 2; nNonOrthogonalCorrectors 0; } relaxationFactors { equations { ".*" 1; } } Is someone of you using IDDES in OpenFoam 5.0? Unfortunately I didn't find any tutorials for DES. Christian |
September 19, 2018, 07:56 |
Syeda
Rep Power: 9 |
Edited: Just found the solution to this problem!! Check below.
How to use DESModelRegions function object Hello, I am also facing the exact same problem. I was wondering whether you've found a solution to this or not? Many thanks. Last edited by S123; September 21, 2018 at 06:54. Reason: Found solution to the problem |
des, iddes, interfoam, les filter |
Anyone using IDDES | cfdmarkus | OpenFOAM Running, Solving & CFD | 18 | June 19, 2021 05:06 |
Smoothing of IDDES delta | Fuchs | OpenFOAM Running, Solving & CFD | 2 | November 17, 2020 12:17 |
IDDES NREL wind turbine | mehran_ansary | FLUENT | 0 | September 22, 2017 06:10 |
Iddes | kebsiali | OpenFOAM Running, Solving & CFD | 0 | August 15, 2016 07:51 |
IDDES in OF2.4 for Sphere on incompressible flow | aerospain | OpenFOAM Running, Solving & CFD | 0 | April 1, 2016 19:23 |
