Reading additional properties in kinematicCloudProperties |
July 10, 2018, 16:39 |
Rep Power: 10 |
Hi all,
I am relatively new to OpenFOAM and I am planning to use StochasticRAS model with icoUncoupledKinematicParcelFoam. However I want to edit that model by reading a few more constant properties specified by the user. How do I edit the code so that it reads the additional properties from the kinematicCloudProperties? Thanks in Advance, Shantanu Vachhani |
constant, dispersion, icouncoupledkinematic, kinematicproperties, stochastic |
[Commercial meshers] Fluent mesh to OF conversion | theHumbleOne | OpenFOAM Meshing & Mesh Conversion | 7 | July 30, 2021 09:44 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
OpenFOAM floating point Error | upuli | OpenFOAM Programming & Development | 5 | June 20, 2016 04:19 |
Coupling two unequal dimension meshes. | RaghavendraRohith | OpenFOAM Programming & Development | 7 | June 14, 2014 12:40 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
