July 2, 2018, 05:27 |
rhoConst & no velocity: error
Rep Power: 11 |
Hello everyone,
I'm using OpenFOAM version 3.0.1 and the solver chtMultiRegionFoam. I've noticed that using rhoConst as thermoType in equationOfState in a case where there's no inlet/outlet flow makes the simulation diverge. This does not happen if an inlet velocity is applied to a boundary. Even in the tutorial case multiRegionHeater, if you set the water velocity (at the bottom of the domain) to 0, the simulation gives strange results and eventually diverges if you have constant density. If you rather set the equationOfState to perfectGas, the case works even with 0 velocity (wall condition). Does anybody know why and how to change settings to make this solver work with static fluid (basically wall conditions without any inlet/outlet flow) and rhoConst? Thank anyone who is willing to answer |
July 2, 2018, 16:56 |
Robin Kamenicky
Rep Power: 11 |
Hi pod,
Could you please share more information about your case? I am interested in it. Anyway, what does drive your flow? You do not have any inlet, outlet, stationary internalField, constRho. Do you have some potential energy or pressure difference? In another words, are those conditions physical? I think there is quite a number of things which can go wrong. Zeros are not friendly sometimes. It leads more often to floating point errors, which is quite logical because its behavior in multiplication and division. Sometime is better to setup very low number. Regarding the tutorial ( I use OF-5.0), if you set the velocity to be zero. There is nothing to solve. Is not it as having closed box of stationary fluid? What should OF compute? Cheers, Robin |
July 3, 2018, 04:47 |
#3 | |
Rep Power: 11 |
Thank you for your answer.
well, there's the heat transfer problem to solve. From the attachment you can see the geometry of my problem. The domain is divided in two parts: a solid one (one the left) and a fluid one (one the right). The boundaries are: supportExt (left surface of solid part), bottomPlate and topPlate, wedge_1 and wedge_2 (lateral), bath (on the right surface of the fluid part). The supportExt is meant to be at a fixed T higher than the rest of the domain. The bath is the only surface not being a wall and the fluid, there, is free to move even though there's no flow coming in or out. This configuration seems to work with perfectGas as thermoType, as I mentioned in the first post. However, once I change it to rhoConst, the simulation crashes. Below the boundary conditions: (solid) dictionaryReplacement { boundary { bottomPlate { type patch; } topPlate { type patch; } wedge_1 { type patch; } wedge_2 { type patch; } supportExt { type patch; } } T { internalField uniform 300; boundaryField { ".*" { type zeroGradient; } "support_to_.*" { type compressible::turbulentTemperatureCoupledBaffleMix ed; Tnbr T; kappa solidThermo; kappaName none; value uniform 300; } supportExt { type fixedValue; value uniform 320; } } } } ///////////////////////////////////////////////////// (fluid) dictionaryReplacement { U { internalField uniform (0 0 0); boundaryField { ".*" { type fixedValue; value uniform (0 0 0); } bath { type zeroGradient; } } } T { internalField uniform 300; boundaryField { ".*" { type zeroGradient; value uniform 300; } "helium_to_.*" { type compressible::turbulentTemperatureCoupledBaffleMix ed; Tnbr T; kappa fluidThermo; kappaName none; value uniform 300; } bath { type fixedValue value uniform 300; } } } epsilon { internalField uniform 0.01; boundaryField { ".*" { type epsilonWallFunction; value uniform 0.01; } bath { type zeroGradient; } } } k { internalField uniform 0.1; boundaryField { ".*" { type kqRWallFunction; value uniform 0.1; } bath { type zeroGradient; } } } p_rgh { internalField uniform 1e5; boundaryField { ".*" { type fixedFluxPressure; value uniform 1e5; } bath { type zeroGradient; } } } p { internalField uniform 1e5; boundaryField { ".*" { type calculated; value $internalField; } } } } |
July 3, 2018, 09:09 |
Rep Power: 11 |
here's the case file.
Can anybody figure out what's wrong? with perfectGas it works fine; with rhoConst it results in crazy T and then diverges but the Courant number is still low enough. thanks |
July 3, 2018, 11:36 |
Lucky
Rep Power: 66 |
My suspicion is here:
p { internalField uniform 1e5; boundaryField { ".*" { type calculated; value $internalField; } } } } Is it right to use the calculated type? I'm not familiar with this solver and setup, but check all your boundary conditions (the non U ones). |
July 4, 2018, 14:24 |
Robin Kamenicky
Rep Power: 11 |
Hi pod,
sorry for quite late answer. What I was trying to say previously is that with velocity prescribed to (0 0 0), no pressure difference and rhoConst there will not be any flow. I would assume, It works with perfectGas since with that equation of state rho is temperature dependent and you get buoyancy force. That is not the case with rhoConst. So you end up with computing only conduction and for that Fourier's law is satisfactory. Does it run when you define perfectGas and g = (0 0 0)? If I am missing something please let me know. Anyway p condition to be calculated make sense since you define p_rgh and p is calculated in a way p = p_rgh +rho*g*h. I had also very very quick look at the case setup. Do you define g field? In the case is (0 0 0). Kind regards, Robin |
chtmultiregionfoam, multiregionheater, rhoconst |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 05:53 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 12:39 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 21:30 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 21:16 |
