Not uniform rim spreading (3D drop impaction)
Old   July 2, 2018, 04:27
Default Not uniform rim spreading (3D drop impaction)
Olivier Huet
Olivier Huet is on a distinguished road
Dear all,
I try to simulate with OpenFOAM the impact of a droplet on a smooth and solid surface but I’m currently facing a problem… The rim behaviour during the spreading phase is not uniform and depends on the flow direction:
- Along the axes (red circle in the screenshot “RimIssue.PNG”): the flow is “cut” before forming some “fingers”.
- Diagonal (green circle in the screenshot “RimIssue.PNG”): the liquid forms some nice “fingers”.
The rim behaviour should be uniform but I don’t know why it is not the case in my simulation. I tried different courant numbers (0.4, 0.25, 0.2, 0.01) but it doesn’t resolve the problem.
You can have a closer look at the rim with “AlongAxes.PNG” and “AlongDiagonal.PNG” screenshots (bottom view). And you can see the dynamic with the gif “Drop-alpha-0_5.gif” (top view).
Here are the parameters of my simulation:
- Version: OpenFOAM v 4.1
- Application: interDyMFoam
- Boundaries:
o Wall: type: constantAlphaContactAngle; theta0: 120; limit: gradient; value: uniform 0;
o Atmosphere: type: inletOutlet; inletValue: uniform 0; value: uniform 0;
- Drop: diameter: 500 µm; initial velocity: 10 m/s, centered, the initial distance between the centre of the drop and the wall is 300 µm
- Mesh
o Dynamic: 4 levels of refinement for 0.001< alpha < 0.999
o Block: cubic shape, Height = 1500 µm, Width = 4000 µm
o hex (0 1 2 3 4 5 6 7) (80 30 80) simpleGrading (1 1 1)
- MaxCo=0.2
- Two phases: air/water
I hope you will help me to find what’s wrong.
Let me know if you need any more details.
Cheers,
Olivier.
Olivier Huet is offline   Reply With Quote
3d simulation, drop impact, not uniform, rim
dsmcFoam setup hherbol OpenFOAM Pre-Processing 1 November 19, 2021 02:52
rSF: p divergence in combustor (wt negative value) zonda OpenFOAM Pre-Processing 4 April 10, 2018 07:59
T Junction Stability ignacio OpenFOAM Running, Solving & CFD 5 May 2, 2013 11:44
[swak4Foam] Air Conditioned room groovyBC Sebaj OpenFOAM Community Contributions 7 October 31, 2012 15:16
Need help with boundary conditions: open to atmosphere Wolle OpenFOAM 2 April 11, 2011 08:32
