Internal Patch Boundary Condition
Old   June 29, 2018, 19:00
Default Internal Patch Boundary Condition
Kellis
Kellis is on a distinguished road
Good afternoon,
I am currently using Foam Extend, v3.2, to model a turbine. The domain consists of 1/8th of an annulus, with cyclic boundary conditions on either side. This setup has been working well but with new additions I am running into issues.
I have added FSI to the solver, and am having issues where the mesh flexes enough to cause an error with the cyclic BC because the mesh on the two sides is deformed differently and no longer "matches." This results in the case crashing. To combat this, I've added two internal baffles as shown below:
The idea is to enforce a zero displacement condition on the points along the baffle, to prevent the cyclic BC from exploding. However, I'm not sure if there are any standard "boundary conditions" that will allow the fluid to pass through as if the wall weren't there.
Am I missing something obvious? Is there another, easier way to go about this? Any help would be much appreciated.
Cheers,
Kellis
Kellis is offline   Reply With Quote
Old   July 2, 2018, 03:52
Peter Baskovich
pete20r2 is on a distinguished road
I have not run FSI myself yet but this kind of "fix" should not be necessary.
Have you read:
http://www.tfd.chalmers.se/~hani/kur...er_reviewd.pdf
pete20r2 is offline   Reply With Quote
baffle, boundary, cyclic, fsi, internal
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 08:30
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
