Problem with a airFoil2D case with another mesh
Old   June 27, 2018, 10:36
Default Problem with a airFoil2D case with another mesh
Iman Sabahi
i.sabahi is on a distinguished road
Dear all
I'm running a case similar to airFoil2D case on OpenFOAM 5.0, and the residuals aren't converging. I've also turned the turbulence off in order to accelerate my solution, I plan to turn it on once i get results without turbulence.
Here is the link to my case file:
https://drive.google.com/open?id=1OC...T_hC-FrZL941Jn
My residuals' plot is in the attachment.
Also my boundary conditions and fvSolution are as follows:
|  \\    /   O peration     | Version:  3.0.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (2.9886 0 0.2615);
boundaryField
    inlet
        type            freestream;
        freestreamValue uniform (2.9886 0 0.2615);
    outlet
        type            freestream;
    topAndBottom
        type            freestream;
    airfoil
        type            noSlip;
    defaultFaces
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            freestreamPressure;
    outlet
    topAndBottom
    airfoil
        type            zeroGradient;
    defaultFaces
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    object      nuTilda;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0.14;
boundaryField
    inlet
        type            freestream;
        freestreamValue uniform 0.14;
    outlet
        type            freestream;
    topAndBottom
        type            freestream;
    airfoil
        type            fixedValue;
        value           uniform 0;
    defaultFaces
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    object      nut;
boundaryField
    inlet
        type            freestream;
    outlet
        type            freestream;
    topAndBottom
        type            freestream;
    airfoil
        type            nutUSpaldingWallFunction;
        value           uniform 0;
    defaultFaces
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver          GAMG;
        tolerance       1e-06;
        relTol          0.1;
        smoother        GaussSeidel;
        nPreSweeps      0;
        nPostSweeps     2;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator    faceAreaPair;
        mergeLevels     1;
    U
        solver          smoothSolver;
        nSweeps         2;
        tolerance       1e-08;
        relTol          0.1;
    nuTilda
        nSweeps         2;
        tolerance       1e-08;
        relTol          0.1;
SIMPLE
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
    residualControl
        p               1e-10;
        U               1e-10;
        nuTilda         1e-10;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
        nuTilda         0.7;
i.sabahi is offline   Reply With Quote
mesh quality problem for displacementSBRStress motion solver zhaozhenkai OpenFOAM 0 January 22, 2017 12:02
[ICEM] ICEM Structured Mesh Problem OMJT ANSYS Meshing & Geometry 3 March 22, 2013 11:06
[GAMBIT] SOFC crossflow mesh possible problem??? epc1 ANSYS Meshing & Geometry 1 February 4, 2013 02:57
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview zhernadi OpenFOAM Meshing & Mesh Conversion 8 July 7, 2011 03:28
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
