September 20, 2021, 11:15
#21
I know it's a long shot, but I have similar problem in my simulations.
Can you share how have you solved your problem ?
Thanks
Originally Posted by Robin.Kamenicky
Dear Foamers,
I have a problem with computational stability of boiling case with reactingTwoPhaseEulerFoam. It diverges and floating point error occurs.
Description: I would like to simulate subcooled boiling of water on the attached geometry. Preferably to simulate all heat transfer stages (vapour blanket, nucleate boiling, natural convection).
Current case: Heat transfer is from the patch called solid_wall. The temperature of the wall is elevated highly beyond the saturation temperature of water at given pressure (Currently constant temperature, no all heat transfer stages needs to be currently observed). Fluid domain is a cylinder tank full of water with outlet on the top (patch called fluid_top). The fluid is not agitated.
The geometry is modelled as wedge (axisymmetric). At the outlet, reverse flow of the liquid phase is allowed.
Due to nature of the problem, one can expect abrupt changes and so stability issues.
The case setup is based on the tutorial $FOAM_TUTORIAL/multiphase/reactingTwoPhaseFlow/RAS/wallBoiling. The main differences are that no inlet is present in my case and very high temperature of the heated wall is used.
Computational Attempts:- run it with PISO algorithm. Computation is more stable but crashes anyway.
- run it with PIMPLE algorithm. The crash speeds up. I am not able to get initial residuals of p_rgh to 1E-4 within 250 nOuterCorrectors (maximum I’ve run), 2 nCorrectors and relaxation factors mentioned in fvSolution. The p_rgh residuals decrease very slowly.
- Initialised k.*, epsilon.*, nut.* with previously run computation with exactly same setting but lower temperature of the heated wall (375K). Problem persists.
- Finer mesh. The simulation crashed even faster.
- K-epsilon turbulence model for liquid and laminar for gas. Problem persists.
- Smaller temperature difference between the heated wall and the fluid. The computation seems to be more stable.
- Many other attempts with changes such as increased minIter for p and h numerical solvers, various relaxation factors, various values of k, epsilon, nut, small initial velocity in the internalField (U.*). Various CFL number, deltaT and maxDeltaT (This helps)
controDict
application reactingTwoPhaseEulerFoam;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 40;
deltaT 1e-7;
writeControl adjustableRunTime;
writeInterval 0.002;
purgeWrite 0;
writeFormat ascii;
writePrecision 9;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
adjustTimeStep yes;
maxCo 0.01;
maxDeltaT 0.0001;
fvSchemes
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
divSchemes
default none;
"div\(phi,alpha.*\)" Gauss vanLeer;
"div\(phir,alpha.*\)" Gauss vanLeer;
"div\(alphaRhoPhi.*,U.*\)" Gauss limitedLinearV 1;
"div\(phi.*,U.*\)" Gauss limitedLinearV 1;
"div\(alphaRhoPhi.*,Yi\)" Gauss limitedLinear 1;
"div\(alphaRhoPhi.*,(h|e).*\)" Gauss limitedLinear 1;
"div\(alphaRhoPhi.*,K.*\)" Gauss limitedLinear 1;
"div\(alphaPhi.*,p\)" Gauss limitedLinear 1;
"div\(alphaRhoPhi.*,(k|epsilon).*\)" Gauss upwind;
"div\(phim,(k|epsilon)m\)" Gauss upwind;
"div\(\(\(\(alpha.*\*thermo:rho.*\)\*nuEff.*\)\*dev2\(T\(grad\(U.*\)\)\)\)\)" Gauss linear;
laplacianSchemes
default Gauss linear uncorrected;
interpolationSchemes
default linear;
snGradSchemes
default uncorrected;
fluxRequired
default no;
wallDist
method meshWave;
nRequired yes;
fvSolution
solvers
"alpha.*"
nAlphaCorr 1;
nAlphaSubCycles 3;
p_rgh
solver GAMG;
smoother DIC;
tolerance 1e-8;
relTol 0.01;
maxIter 100;
minIter 2;
p_rghFinal
$p_rgh;
relTol 0;
"U.*"
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-6;
relTol 0;
minIter 1;
"(e|h).*"
tolerance 1e-12;
relTol 0.001;
minIter 1;
maxIter 20;
"(k|epsilon|Theta).*"
tolerance 1e-8;
relTol 0;
minIter 1;
Yi
tolerance 1e-6;
relTol 0;
minIter 1;
residualAlpha 1e-8;
PIMPLE
momnetumPredictor yes;
nOuterCorrectors 250;
nCorrectors 2;
nNonOrthogonalCorrectors 0;
nEnergyCorrectors 2;
faceMomentum yes;
residualControl
p_rgh
relTol 0;
tolerance 1e-4;
relaxationFactors
fields
iDmdt 0.1;
p_rgh 0.1;
p_rghFinal 0.6;
equations
".*" 1;
"h.*" 0.1;
"U.*|k.*|epsilon.*|alpha.*" 0.1;
phaseProperties
type thermalPhaseChangeTwoPhaseSystem;
phases (gas liquid);
volatile "water";
massTransfer on;
gas
type multiComponentPhaseModel;
diameterModel isothermal;
constantCoeffs
d 0.00045;
isothermalCoeffs
d0 0.00045;
p0 1e5;
Sc 0.7;
residualAlpha 1e-4;
liquid
diameterModel constant;
constantCoeffs
d 0.00045;
Sc 0.7;
residualAlpha 1e-4;
blending
default
type linear;
continuousPhase liquid;
minFullyContinuousAlpha.gas 0.7;
minPartlyContinuousAlpha.gas 0.5;
minFullyContinuousAlpha.liquid 0.7;
minPartlyContinuousAlpha.liquid 0.5;
heatTransfer
type linear;
minFullyContinuousAlpha.gas 1;
minPartlyContinuousAlpha.gas 0;
minFullyContinuousAlpha.liquid 1;
minPartlyContinuousAlpha.liquid 0;
massTransfer
type linear;
surfaceTension
(gas and liquid)
type constant;
sigma 0.07;
saturationModel
type polynomial;
C<8>
308.0422
0.0015096
-1.61589e-8
1.114106e-13
-4.52216e-19
1.05192e-24
-1.2953e-30
6.5365e-37
aspectRatio
(gas in liquid)
type constant;
E0 1.0;
(liquid in gas)
type constant;
E0 1.0;
drag
(gas in liquid)
type SchillerNaumann;
residualRe 1e-3;
swarmCorrection
type none;
(liquid in gas)
residualRe 1e-3;
swarmCorrection
type none;
virtualMass
(gas in liquid)
type constantCoefficient;
Cvm 0.5;
(liquid in gas)
Cvm 0.5;
interfaceComposition
heatTransfer.gas
(gas in liquid)
type spherical;
residualAlpha 1e-3;
(liquid in gas)
type RanzMarshall;
residualAlpha 1e-3;
heatTransfer.liquid
(gas in liquid)
type RanzMarshall;
residualAlpha 1e-3;
(liquid in gas)
type spherical;
residualAlpha 1e-3;
massTransfer.gas
massTransfer.liquid
lift
wallLubrication
(gas in liquid)
type Antal;
Cw1 -0.01;
Cw2 0.05;
Cwc 10.0;
Cwd 6.8;
p 1.7;
turbulentDispersion
(gas in liquid)
type Burns;
sigma 0.7;
Ctd 1.0;
residualAlpha 1e-3;
// Minimum allowable pressure
pMin 10000;
thermophysicalProperties.gas
thermoType
type heRhoThermo;
mixture multiComponentMixture;
transport const;
thermo hRefConst;
equationOfState perfectGas;
specie specie;
energy sensibleEnthalpy;
dpdt yes;
species
water
inertSpecie water;
/* chemistryReader foamChemistryReader; */
/* foamChemistryFile "$FOAM_CASE/constant/reactions.gas"; */
water
specie
molWeight 18.0153;
equationOfState
rho 1;
thermodynamics
Hf 0;
Cp 12078.4;
Tref 373.55;
Href 2675500;
transport
mu 1.2256e-5;
Pr 2.289;
thermophysicalProperties.liquid
thermoType
type heRhoThermo;
transport const;
thermo hRefConst;
equationOfState perfectFluid;
specie specie;
dpdt yes;
species
water
inertSpecie water;
"(mixture|H2O|water)"
specie
molWeight 18.0153;
equationOfState
R 3000;
rho0 959;
rho 959;
thermodynamics
Hf 0;
Cp 4195;
Tref 373.55;
Href 417500;
transport
mu 2.8291e-4;
Pr 2.289;
p_rgh
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 100000;
boundaryField
fluid_bottom
type fixedFluxPressure;
fluid_top
type prghTotalPressure;
U U.liquid;
p0 uniform 100000;
value uniform 100000;
tank_wall
solid_wall
right
type wedge;
left
type wedge;
Part of log
gas min/max T 307.702909 - 2016.44048
liquid min/max T 359.969529 - 2389.91521
Tf.gasAndLiquid: min = 359.983643, mean = 367.376591, max = 403.907099
iDmdt.gasAndLiquid: min = -2137.69475, mean = -92.2414632, max = -2.62873604e-23, integral = -0.000462413491
wDmdt.gasAndLiquid: min = 0, mean = 1.94094026, max = 22.9273172, integral = 2.7677863e-07
dmdt.gasAndLiquid: min = -2114.76743, mean = -90.300523, max = -2.62873604e-23, integral = -0.000462136713
smoothSolver: Solving for h.gas, Initial residual = 0.000705340909, Final residual = 1.52402318e-13, No Iterations 1
smoothSolver: Solving for h.liquid, Initial residual = 0.0354795666, Final residual = 9.77502319e-18, No Iterations 1
gas min/max T 307.726027 - 1868.00206
liquid min/max T 359.969529 - 2538.90673
Tf.gasAndLiquid: min = 359.983643, mean = 367.376596, max = 403.907099
iDmdt.gasAndLiquid: min = -2167.11375, mean = -92.7952508, max = -2.63187519e-23, integral = -0.000411679688
wDmdt.gasAndLiquid: min = 0, mean = 1.94114191, max = 22.9373728, integral = 2.76781142e-07
dmdt.gasAndLiquid: min = -2144.17637, mean = -90.8541089, max = -2.63187519e-23, integral = -0.000411402907
GAMG: Solving for p_rgh, Initial residual = 0.232598235, Final residual = 7.74806493e-17, No Iterations 2
GAMG: Solving for p_rgh, Initial residual = 0.246949424, Final residual = 1.06193819e-16, No Iterations 2
PIMPLE: iteration 2
MULES: Solving for alpha.gas
alpha.gas volume fraction = 0.000147084939 Min(alpha1) = 5.96787709e-101 Max(alpha1) = 0.247168508
Constructing face momentum equations
smoothSolver: Solving for h.gas, Initial residual = 0.668877348, Final residual = 7.52677685e-06, No Iterations 2
smoothSolver: Solving for h.liquid, Initial residual = 0.0363311226, Final residual = 1.12267408e-17, No Iterations 1
gas min/max T -10269.4458 - 2197.07427
liquid min/max T 359.969529 - 2702.79741
[6] #0 Foam::error::printStack(Foam::Ostream&)Tf.gasAndLiquid: min = 359.983642, mean = 367.375326, max = 403.881676
at ??:?
[6] #1 Foam::sigFpe::sigHandler(int) at ??:?
[6] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
[6] #3 Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) at ??:?
[6] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::sqrt<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
[6] #5 Foam::heatTransferModels::RanzMarshall::K(double) const at ??:?
[6] #6 Foam::BlendedInterfacialModel<Foam::heatTransferModel>::K(double) const at ??:?
[6] #7 Foam::ThermalPhaseChangePhaseSystem<Foam::MomentumTransferPhaseSystem<Foam::twoPhaseSystem> >::correctThermo() at ??:?
[6] #8 ? at ??:?
[6] #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[6] #10 ? at ??:?
[MAE-ROW-RK:25098] *** Process received signal ***
[MAE-ROW-RK:25098] Signal: Floating point exception (8)
[MAE-ROW-RK:25098] Signal code: (-6)
[MAE-ROW-RK:25098] Failing at address: 0x3e80000620a
[MAE-ROW-RK:25098] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f3cc8e714b0]
[MAE-ROW-RK:25098] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7f3cc8e71428]
[MAE-ROW-RK:25098] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f3cc8e714b0]
[MAE-ROW-RK:25098] [ 3] /home/robin/OpenFOAM/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam4sqrtERNS_5FieldIdEERKNS_5UListIdEE+0x28)[0x7f3cca329f58]
[MAE-ROW-RK:25098] [ 4] /home/robin/OpenFOAM/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libreactingTwoPhaseSystem.so(_ZN4Foam4sqrtINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKS8_+0x10a)[0x7f3cce32d20a]
[MAE-ROW-RK:25098] [ 5] /home/robin/OpenFOAM/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libreactingEulerianInterfacialModels.so(_ZNK4Foam18heatTransferModels12RanzMarshall1KEd+0x7d)[0x7f3ccdf79a2d]
[MAE-ROW-RK:25098] [ 6] /home/robin/OpenFOAM/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libreactingTwoPhaseSystem.so(_ZNK4Foam23BlendedInterfacialModelINS_17heatTransferModelEE1KEd+0x410)[0x7f3cce393fa0]
[MAE-ROW-RK:25098] [ 7] /home/robin/OpenFOAM/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libreactingTwoPhaseSystem.so(_ZN4Foam29ThermalPhaseChangePhaseSystemINS_27MomentumTransferPhaseSystemINS_14twoPhaseSystemEEEE13correctThermoEv+0xa0e)[0x7f3cce394ebe]
[MAE-ROW-RK:25098] [ 8] reactingTwoPhaseEulerFoam[0x436585]
[MAE-ROW-RK:25098] [ 9] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f3cc8e5c830]
[MAE-ROW-RK:25098] [10] reactingTwoPhaseEulerFoam[0x44bb69]
[MAE-ROW-RK:25098] *** End of error message ***
mpirun noticed that process rank 6 with PID 25098 on node MAE-ROW-RK exited on signal 8 (Floating point exception).
Very high epsilon values are usually observed in the vicinity of the heated wall shortly before the crashes.
I enclose part of the case and a few pictures. Any recommendation/suggestion is welcomed.
Thanks,
Robin
