interFoam diverging after approx. 12000 iterations. |
Rep Power: 8 ![]() |
Hello Foamers,
I am running water-atmosphere interface simulation in a complex domain. As it can be seen in the attached screenshot, the simulation is diverging after around 12000 iterations. To reach this point, I tweaked relaxation factors and finallz found a combination with which the simulation was converging. What could be the probable reasons for the simulation to diverge after behaving normallz at the start?? HTML Code:
FoamFile { version 2.0; format ascii; class dictionary; location system; object fvSolution; } solvers { "alpha.water_copy.*" { nAlphaCorr 2; nAlphaSubCycles 1; cAlpha 1; MULESCorr yes; nLimiterIter 2; solver smoothSolver; smoother symGaussSeidel; tolerance 1e-5; relTol 0.0; } "pcorr.*" { solver GAMG; preconditioner GAMG; tolerance 1e-3; relTol 0.0; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 100; agglomerator faceAreaPair; mergeLevels 1; minIter 1; } p_rgh { solver GAMG; agglomerator faceAreaPair; mergeLevels 1; cacheAgglomeration no; nCellsInCoarsestLevel 10; tolerance 1e-5; relTol 0.02; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; minIter 1; } p_rghFinal { solver GAMG; smoother GaussSeidel; agglomerator faceAreaPair; mergeLevels 1; cacheAgglomeration true; nCellsInCoarsestLevel 256; tolerance 1e-3; relTol 0.0; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; minIter 1; } U { solver smoothSolver; smoother GaussSeidel; tolerance 1e-3; relTol 0.01; minIter 1; } UFinal { solver smoothSolver; smoother GaussSeidel; tolerance 1e-3; relTol 0.0; minIter 1; } } PIMPLE { momentumPredictor on; nOuterCorrectors 50; nCorrectors 1; nNonOrthogonalCorrectors 1; residualControl { p_rgh { relTol 0.0; tolerance 1.0E-3; } U { relTol 0.0; tolerance 1.0E-3; } alpha.water_copy { tolerance 1.0E-3; relTol 0.0; } } } relaxationFactors { equations { ".*" 1; U 0.3; UFinal 1.0; alpha.water_copy 1.0; alpha.water_copyFinal 1.0; } fields { p_rgh 0.3; p_rghFinal 1; } } HTML Code:
FoamFile { version 2.0; format ascii; class dictionary; location system; object controlDict; } application interFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 0.02; deltaT 1.0E-7; writeControl adjustableRunTime; writeInterval 0.005; purgeWrite 0; writeFormat ascii; writePrecision 8; writeCompression uncompressed; timeFormat general; timePrecision 6; graphFormat raw; runTimeModifiable yes; adjustTimeStep true; maxCo 2.0; maxAlphaCo 1.0; maxDeltaT 1.0; HTML Code:
Checking geometry... Overall domain bounding box (-0.0208 -0.026000001 -3.1211903e-07) (1.4953394e-08 0.037999999 0.0050045401) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (6.4313919e-15 -2.2156182e-15 -1.5696621e-14) OK. Max cell openness = 3.5470582e-16 OK. Max aspect ratio = 15.799183 OK. Minimum face area = 5.3008842e-12. Maximum face area = 2.5102548e-07. Face area magnitudes OK. Min volume = 3.5968209e-16. Max volume = 1.0664251e-10. Total volume = 1.7086181e-06. Cell volumes OK. Mesh non-orthogonality Max: 69.964055 average: 10.019463 Non-orthogonality check OK. Face pyramids OK. Max skewness = 3.2972868 OK. Coupled point location match (average 0) OK. Mesh OK. Regards, Rajan |
interfoam, multiphase, residula |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 12:30 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 22:13 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
