validation k-omega-sst on flat plate questions? |
June 25, 2018, 10:13 |
Timo
Rep Power: 8 |
Hey everybody,
At the moment I am trying to validate some experiments to see if SimpleFOAM can accurately describe the boundary layer of a flat plate as I hope to move on towards airfoils including surface roughness soon. Because my target application is incompressible flow (M<0.1) and all happening at room temperature I do not include any temperature effects as in the case of a Blasius flat plate. I performed the 3 following cases: 1. RANS + k-omega-sst turbulence model in low Reynolds form (many points for y+<1) 2. RANS + k-omega-sst turbulence model in high Reynolds form (model the viscous sub region) (nut -> nutkRoughWallFunction) 3. RANS + k-omega-sst turbulence model also in high Reynolds form but including surface roughness (nut -> nutkRoughWallFunction) There are some things that I noticed when looking at the results that I don't get:
Is k-omega-sst model bad at estimating the true boundary and momentum thickness? Or is it too optimistic when computing the skin friction coefficient? Or are there other factors that I'm not taking into account that I should've taken into account? Thanks a lot in advance! Timo |
June 28, 2018, 03:40 |
#2 | |
Ehsan Asgari
Rep Power: 18 |
Hi Timo, I haven't done RANS simulation for flat plate, but couple of things come to my mind. 1-make sure you are applying correct boundary conditions for k and omega. When I was using OF 2.3.1, I applied a constant value and a wall-function at the wall for k and omega, respectively. I do not remember if nut was defined there. 2-compare your results with DNS of flat plate. There are good researches and boundary-layer profile database on the web. See the links below: https://torroja.dmt.upm.es/ftp/blayers/ https://www.mech.kth.se/~pschlatt/DATA/ 3-compare the local velocity profile of the boundary-layer with the references. This way, you may get a sense of whereabouts the problem lies by examining the velocity profile. 4-the last but not the least, make sure you have applied the correct boundary conditions which would allow a proper spatial growth of the boundary-layer. I hope these points will help you find the problem. Regards, Syavash |
k-omega-SST model (OF 1.6) - turbulent flat plate | cboss | OpenFOAM Running, Solving & CFD | 25 | August 9, 2016 10:53 |
Flat Plate Boundary Layer Height | kennedy1992 | Fidelity CFD | 7 | February 24, 2016 05:45 |
Flat plate analysis in cfx | hamed.majeed | CFX | 14 | February 4, 2015 08:07 |
Cf over flat plate obtained by SST k-omega | mb.pejvak | Main CFD Forum | 0 | June 8, 2012 21:16 |
flat plate transition: SST k-omega divergence | Peter Gasparovic | FLUENT | 4 | May 3, 2005 14:54 |
