Unexplained Velocities Using BuoyantBoussinesqPimpleFoam
Old   June 19, 2018, 11:00
Default Unexplained Velocities Using BuoyantBoussinesqPimpleFoam
Jonty Pedersen
J_here is on a distinguished road
Hi All,
I am trying to simulate a vertical heated plate on a column surrounded by atmospheric boundary conditions (see attached image) and these unexplained velocities develop either at the bottom left corner or at the intersection of the column and the bottom on the heated surfaces side.
My 0 files are as follows:
alphat
 dimensions      [0 2 -1 0 0 0 0];  //m^2/s
internalField   uniform 0;
boundaryField
    heatedSurface
        type            alphatJayatillekeWallFunction;
        Prt             1;
        value           uniform 0;
    fixedWalls
        Prt             1;
        value           uniform 0;
    openAir
        type            calculated;
	value		uniform 0;
    frontAndBack
        type            empty;
epsilon
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform 0.01;
boundaryField
    heatedSurface
        type            epsilonWallFunction;
        value           uniform 0.01;
    fixedWalls
        value           uniform 0.01;
    openAir
        type            inletOutlet;
        inletValue      uniform 0.01;
        value           uniform 0.01;
    frontAndBack
        type            empty;
k
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0.1;
boundaryField
    heatedSurface
        type            kqRWallFunction;
        value           uniform 0.1;
    fixedWalls
        value           uniform 0.1;
    openAir
        type            inletOutlet;
        inletValue      uniform 0.1;
        value           uniform 0.1;
    frontAndBack
        type            empty;
nut
boundaryField
    heatedSurface
        type            nutkWallFunction;
        value           uniform 0;
    fixedWalls
        value           uniform 0;
    openAir
        type            calculated;
        value           uniform 0;
    frontAndBack
        type            empty;
p
boundaryField
    heatedSurface
        type            calculated;
        value           $internalField;
    fixedWalls
        type            calculated;
    openAir
        type            calculated;
    frontAndBack
        type            empty;
p_rgh
boundaryField
    heatedSurface
        type            fixedFluxPressure;
        rho             rhok;
        value           uniform 0;
    fixedWalls
        rho             rhok;
        value           uniform 0;
    openAir
        rho             rhok;
        value           uniform 0;
    frontAndBack
        type            empty;
T
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 300;
boundaryField
    heatedSurface
        type            fixedValue;
        value           uniform 305;
    fixedWalls
        type           zeroGradient;
    openAir
        type            inletOutlet;
        inletValue      uniform 300;
        value           uniform 300;
    frontAndBack
        type            empty;
and finally U
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    heatedSurface
        type            noSlip;
    openAir
        type            pressureInletOutletVelocity;
        outletValue     uniform (0 0 0);
        value           uniform (0 0 0);
    fixedWalls
	  type           noSlip;
    frontAndBack
        type            empty;
I have looked elsewhere on the forum but nothing specifically deals with this. Or if it is similar like 'atmospheric boundary conditions for hotRoom' it is with an old version of openFoam.
Thanks in advance for any help or guidance you can spare
File Type: jpg Velocity developing in bottom left hand corner.jpg (44.8 KB, 14 views)
J_here is offline   Reply With Quote
atmospheric outlet, boundary condition, buoyantboussinesqpimple, hotroom, velocities
2 fixed inlet velocities lead to steady time step decrease in interFoam rheise OpenFOAM Running, Solving & CFD 7 July 3, 2017 07:24
Calculating vortex cores of relative velocities Dorit Tecplot 1 December 17, 2015 06:23
[OpenFOAM] converting velocities from cell centers to corner torsy87 ParaView 1 April 14, 2013 09:09
Time mean velocities in moving meshes Pfalcon FLUENT 0 August 14, 2009 14:51
Derived velocities from loss coefficients ?? jakjak CFX 1 December 20, 2007 15:38
