Calculate concentrations that change by orders of magnitude.
Old   June 18, 2018, 04:22
Default Calculate concentrations that change by orders of magnitude.
manu ebn
Triggin is on a distinguished road
Hi to everyone
I have a very simple question, but i couldn't find any answer to that so far...
Lets say: you have a domain which contains oxygen (concentration of 21% - therefore air) and an inlet which flushes the domain with nitrogen.
Due to an imperfect system, the stationary concentration at a certain point is 100 ppm.
21% O2 (= 210'000 ppm) compared to 100 ppm is 2100 times bigger.
If you do measurements and compare those to the simulation results, what is the accuracy you expect at that low concentration point?
Usually one can say a simulation should achieve an accuracy of lets say 10%. But what are those 10% referenced to? To the highest value (21%) or to the local value (100 ppm) ?
Any discussion would be appreciated
Best, Triggin
Triggin is offline   Reply With Quote
Old   June 21, 2018, 03:19
manu ebn
Has no one had a similar experience...?
accuracy, validation
calculate velocity difference helly OpenFOAM Post-Processing 0 June 21, 2016 09:49
Stage Frame Change + Porous Domain CFX_Beginner CFX 10 August 10, 2015 05:28
how to calculate the magnitude (module) of a gradient Alucard OpenFOAM 2 October 28, 2011 05:43
Mixing = density change Paul Main CFD Forum 0 March 1, 2005 08:48
calculate average magnitude Ethan Siemens 1 June 3, 2003 13:34
