Writing output with pimpleFoam
Old   June 7, 2018, 12:31
Default Writing output with pimpleFoam
Thi
Arthi Appathurai
Thi is on a distinguished road
Hello all!
I am simulating the flow past a cylinder in a circular channel using the kOmegaSST turbulence model. Besides the usual output fields (p, U, k, omega, etc) I am also interested in the vorticity, and the force coefficients and wall shear stress on the cylinder. In order to write these additional fields I wrote functions in the function block of my controlDict (attached here as a txt file). My simulations run fine - no convergence issues. However, I am not able to get the usual output fields. The program only writes the additional fields.
I tried to run a case without the functions block. The program runs fine (I can attach the log file if you think that could help) but does not write any output. I tried restarting my computer in an attempt to call upon my random luck to workout. Unfortunately, luck has failed me. I am convinced this is a trivial error that I am overlooking but I am not able to figure this out! I am on sort of a time crunch - this is for a summer internship where we hope to run such simulations on different cylinders. Given how long these simulations tend to take to run, I would like to get the CFD framework figured out ASAP.
I would greatly appreciate your help in figuring this out!
Disclosure: This is also my first time posting on this forum. I thought I submitted this question but did not see the thread show up on the main page. Apologies if this is, in fact, a repeat posting.
Arthi
Thi is offline   Reply With Quote
Old   June 11, 2018, 05:42
Joachim Herb
jherb is on a distinguished road
You set the writeInterval to 10 s which is the end time of your simulation. So no intermediate writes.
If you want to output every time iteration step, use:
writeControl    timeStep;
writeInterval   1;
If you want an output for each second, use:
writeControl    adjustableRunTime;
writeInterval   1;
jherb is offline   Reply With Quote
Old   June 11, 2018, 16:04
Thi
Arthi Appathurai
Thanks, Joachim!
So adjustableRunTime is measured in seconds and not number of time steps? My reasoning behind declaring writeInterval 10 was that I wanted OpenFOAM to write the results every 10 time steps. Is there a way to specify this with adjustableRunTime control?
Arthi
output, pimplefoam, writecontrol
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
What variable should I output to get wall force? Pauli CFX 6 May 15, 2018 08:58
[mesh manipulation] Dynamic remeshing (mequite) in parallel not working [foam-extend-4.0] Peter_600 OpenFOAM Meshing & Mesh Conversion 4 August 1, 2017 07:07
Writing output of a scalar in each time step mehranism OpenFOAM Programming & Development 2 July 9, 2017 14:05
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
