OpenFoam 2.3 Difference between src/turbulencemodels and src/TurbulenceModels |
Nishanth Murugan
Rep Power: 8 ![]() |
I'm converting a Solver from OpenFOAM 2.3 to 5.0 and I'm facing an issue w.r.t turbulence modelling as they are very different in both the versions.
The 2.3 version has two directories in the src folder named as turbulencemodels and Turbulencemodels while the 5.0 version has a single Turbulencemodels. Can anyone tell how and why such a change was brought about? Thanks ! ![]() |
Gerhard Holzinger
Rep Power: 28 ![]() ![]() |
What you describe, the folders src/turbulenceModel and src/TurbulenceModel being present, is the transition from the old/initial implementation of turbulence modelling to the new one. This transition was completed with OpenFOAM-3.0.
See The commit message by Henry Weller and the Release Notes of OpenFOAM-3.0 |
openfoam2.3, openfoam5, turbulence modeling |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 26 | June 21, 2024 06:54 |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 15:54 |
high-order difference in OpenFOAM | rxgrch | OpenFOAM Programming & Development | 6 | August 28, 2017 14:11 |
Difference between OpenFOAM on Centos 7 and On Windows 10 (cygwin) | JensGoldberg | OpenFOAM Programming & Development | 0 | November 10, 2016 03:30 |
OpenFOAM Training Beijing 22-26 Aug 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | May 3, 2016 04:57 |
