Graceful stop for running on clusters with time limit? |
June 5, 2018, 20:53 |
TWB
Rep Power: 19 |
I am running OF on clusters with a time limit of 24hr. I'm using a modified OF which writes certain info at the end of the simulation. I found that for certain problems, if it stops at the 24hr limit, it will not finish writing the info and hence I'm not able to restart from where it ended. Hence, I am wondering if I can set something such that OF will end gracefully after 23hr 55 min? Thanks! |
June 6, 2018, 02:54 |
Rep Power: 21 |
writeControl cpuTime; // Writes data every writeInterval seconds of CPU time. writeControl clockTime; // Writes data out every writeInterval seconds of real time. |
June 6, 2018, 03:39 |
Gerhard Holzinger
Rep Power: 28 |
Use the abort functionObject to make OpenFOAM gracefully stop, when it detects the presence of a certain file.
Class Foam::functionObjects::abort Description Watches for presence of the named file in the $FOAM_CASE directory and aborts the calculation if it is present. Currently the following action types are supported: - noWriteNow - writeNow - nextWrite See e.g. https://stackoverflow.com/questions/...time-in-future This way, you retain the ability to write out at fixed intervals, as graceful stopping is independent of writing out the data. However, this is merely a question of personal preference. |
June 6, 2018, 04:13 |
#4 | |
Hosein
Rep Power: 14 |
I'm just curious to know what happens if your simulation stops due to time limit by the time that 24 hours is reached, and then the next day you try to send the job but this time change the controlDict entry to start from "latestTime"? is there anything wrong with this approach? |
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 42 | May 7, 2024 23:17 |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
