June 1, 2018, 07:45 |
Help with chtMultiRegionSimpleFoam
Rep Power: 8 |
i desperately seek help for a problem i have with chtMultiRegionSimpleFoam. I try to simlulate a testcase for my thesis. The geometry is a simple cube (SOLIDWURFEL) with a straight, cylindrical oil channel (FLUIDROHR) through it. The oil is supposed to heat the cube. The problem is, whenever i try to simluate the process, i get one of two error messages: 1) Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 291125.4 Specified mass inflow : 7442.71 Specified mass outflow : 0 Adjustable mass outflow : 0 From function bool Foam::adjustPhi(Foam::surfaceScalarField&, const volVectorField&,volScalarField&) in file cfdTools/general/adjustPhi/adjustPhi.C at line 107. 2) Negative initial temperature T0: -0.6823983 From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam::rhoConst<Foam::specie> >; Type = Foam::sensibleEnthalpy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::rho Const<Foam::specie> >, Foam::sensibleEnthalpy>] in file /home/pawan/OpenFOAM/OpenFOAM-v1712/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 54. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::heRhoThermo<Foam::rhoThermo, Foam:ureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam::rhoConst<Foam: :specie> >, Foam::sensibleEnthalpy> > > >::calculate(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, bool) at ??:? #3 Foam::heRhoThermo<Foam::rhoThermo, Foam:ureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam::rhoConst<Foam: :specie> >, Foam::sensibleEnthalpy> > > >::correct() at ??:? #4 ? at ??:? #5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #6 ? at ??:? Abgebrochen (Speicherabzug geschrieben) The system folder, the 0 folder and a picture of the geometry are attached. "WURFEL" is the surface of the cube, "ROHRAUSEN" is the shared face of the oil channel and the cube. I don't have any clue where the problem is and i hope somebody can help me, please. Thanks in advance. |
June 1, 2018, 07:58 |
Temperature dependent density
Tomas Denk
Rep Power: 9 |
Hi Lexe,
I faced the same problem and I wasn't able to resolve it yet. I also posted question in this forum several weeks ago, but received no answer, so far. I think, you should also attach constant directory, because I assume you have temperature dependent density of the oil in your case. That turned out to be the major proble maker in my case. With constant density, everything works just fine. I suspect there is an error in continuity check classes. I use flowRateInletVelocity on the inlet and flowRateOutletVelocity on the outlet boundary conditions for U, both set massFlowRate to 1. I suspect that at some point durig the check, massFlowRate is mixed up with volumetricFlowRate and changing density leads to the error. I hope someone competent will reply to this thread and post fix or at least workaround. |
June 2, 2018, 00:46 |
Rep Power: 8 |
I tried to upload the constant folder, but it is simply to big, even if i split it up.
June 4, 2018, 03:44 |
Tomas Denk
Rep Power: 9 |
It is probably too big because of mesh. You can remove the mesh and leave only properties. Such .zip file will be small enough.
June 4, 2018, 09:44 |
Rep Power: 21 |
Continuity error cannot be removed by adjusting the outflow Code:
Negative initial temperature T0 Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object fvOptions; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // limitT { type limitTemperature; active yes; limitTemperatureCoeffs { selectionMode all; min 338; max 500; Tmin 338; // syntax depends on the of version Tmax 500; } } //************************************************************************ // Code:
checkMesh -region SOLIDWURFEL -allTopology -allGeometry checkMesh -region FLUIDROHR -allTopology -allGeometry This solver uses p_rgh to calculate everything. p = p_rgh + rho*g*h is just the absolute pressure which is calculated for your convenience. Hence all boundaries are calculated. You should also check rhoMin and rhoMax in your fvSolution file. Those do not seem appropriate. |
June 4, 2018, 10:16 |
Tomas Denk
Rep Power: 9 |
Hello Bloerb,
Could you, by any chance, take a look at my case. It uses different setup (BCs), but I experience the same problem with "Continuity error cannot be removed..." My question in this blog is here Thanks, Tomas |
June 5, 2018, 09:14 |
Rep Power: 8 |
Thank you very much Bloerb.
The simulation is still a bit odd, but at least the errors are gone. I've added the "corrected" folders, maybe someone finds something to improve the simulation. |
