Error while running new solver phaseChangeHeatDyMFoam
Old   June 1, 2018, 04:44
Default Error while running new solver phaseChangeHeatDyMFoam
Sabrina Carson
sabrinacarson is on a distinguished road
I have modified custom solver phaseChangeHeatFoam with dyanmic mesh capabilities. New solver is called phaseChangeHeatDyMFoam.
The solver is working fine when I am working with boiling of static liquid, as the phase is changing the mesh is adapting according to alpha value at the interface.
But, If I am working with annular two phase flow of gas and liuid in cylinder having degree of superheat applied on the wall (fluid is having velocity now, its not static as earlier). as soon as it starts adapting the mesh the solver stops. It shows following error:
PHP Code:
Create time
Create mesh
for time 0
Selecting dynamicFvMesh dynamicRefineFvMesh
Reading field p_rgh
Reading field T
Reading field alpha1
Reading field U
Reading
/calculating face flux field phi
Creating phaseChangeTwoPhaseMixture
Selecting phaseChange model Hardt
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Reading g
Reading hRef
Calculating field g
.h
No finite volume options present
Creating field kinetic energy K
PIMPLE
Operating solver in PISO mode
time step continuity errors
sum local 1.36275e-21, global = 8.21085e-24cumulative 8.21085e-24
GAMG
:  Solving for pcorrInitial residual 0.434647, Final residual 5.36898e-05No Iterations 7
sum local 8.03698e-22, global = -2.9247e-23cumulative = -2.10362e-23
Courant Number mean
0.00060848 max0.000819
Starting time loop
Interface Courant Number mean0 max0
Courant Number mean
deltaT
1e-06
Time
1e-06
Selected 6760 cells
for refinement out of 27885.
Refined from 27885 to 75205 cells
Selected 0 split points out of a possible 6760.
Execution time
for mesh.update() = 0.35 s
sum local 1.04334e-19, global = 9.02229e-22cumulative 8.81193e-22
GAMG
:  Solving for pcorrInitial residual 0.983295, Final residual 9.04202e-05No Iterations 7
sum local 2.74338e-20, global = 7.31173e-22cumulative 1.61237e-21
MULES
Solving for alpha1
Liquid phase volume fraction
0.305544  Min(alpha1) = 0  Max(alpha1) = 1
MULES
Solving for alpha1
0.305544  Min(alpha1) = -5.31557e-37  Max(alpha1) = 1
MULES
Solving for alpha1
0.305544  Min(alpha1) = -9.65276e-37  Max(alpha1) = 1
MULES
Solving for alpha1
0.305544  Min(alpha1) = -5.9622e-37  Max(alpha1) = 1
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::mag<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
#4  Foam::smoothInterfaceProperties::calculateK() at ??:?
at ??:?
#6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
RUN.shline 3727615 Floating point exception(core dumpedphaseChangeHeatDyMFoam
The boundary conditions, fvschemes and fvsolution are given below in folder:
Click here : https://drive.google.com/open?id=1IT...FO7H-EDNlHlXWj
sabrinacarson is offline   Reply With Quote
Old   June 10, 2018, 06:31
Nima Samkhaniani
nimasam is on a distinguished road
Dear Sabrina
it seems the error is related to the library smoothInterfaceProperties which is a modified version of interfaceProperties. Therefore, i recommend to use the original library of OpenFOAM, and go forward.
smoothInterfaceProperties as i mentioned in my published paper is to eliminate parasite current. it is not vital for your implementation.
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   June 13, 2018, 08:59
Sabrina Carson
Originally Posted by nimasam View Post
Dear Sabrina
Thanks. It actually worked. I used interfaceProperties.H instead of smoothInterfaceProperties.H
But I am getting spurious currents around the interface. Interface is not smooth, (smoothinterfaceproperties also gave spurious currents kind of result in phaseChangeHeatDyMFoam)
Please find the attachment to see the results.
What can be the solution?
Old   June 14, 2018, 14:41
Nima Samkhaniani
i guess you may need to update phi and rhoPhi after mesh refinement, it may helps you to get better result, it is far more than parasite current problem
Old   July 10, 2018, 08:28
Sabrina Carson
Thanks for your reply. I was trying few other ways to make the solver correct, but didn't work.
How the values of phi and rhoPhi will be updated? In which particular file these values are being updated?
error, new solver, openfoam
New solver not running in loop. silviliril OpenFOAM Running, Solving & CFD 2 May 21, 2018 09:55
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 10:52
Error Message when running solver Jiang CFX 4 August 12, 2013 14:37
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
