pairCollision in IcoUncoupledKinematicParcelFoam crashes |
May 31, 2018, 13:27 |
Rep Power: 10 |
Hi everybody,
I am trying to use the pairCollision model in IcoUncoupledKinematicParcelFoam in OpenFOAM 1706. However the simulation crashes and gives the following error message. It gives a floating point exception which may be due to the division of a very small quantity. How do I rectify the problem? Does it involve changing the code? Thanks in advance [1] #0 Foam::error:rintStack(Foam::Ostream&) at ??:? [1] #1 Foam::sigFpe::sigHandler(int) at ??:? [1] #2 ? in "/lib64/libc.so.6" [1] #3 ? in "/lib64/libm.so.6" [1] #4 Foam::PairSpringSliderDashpot<Foam::CollidingCloud <Foam::KinematicCloud<Foam::Cloud<Foam::CollidingP arcel<Foam::KinematicParcel<Foam:article> > > > > >::nSubCycles() const at ??:? [1] #5 Foam::PairCollision<Foam::CollidingCloud<Foam::Kin ematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam ::KinematicParcel<Foam:article> > > > > >::nSubCycles() const at ??:? [1] #6 ? at ??:? [1] #7 ? at ??:? [1] #8 ? at ??:? [1] #9 ? at ??:? [1] #10 ? at ??:? [1] #11 __libc_start_main in "/lib64/libc.so.6" [1] #12 ? at ??:? [n2c2-13:09768] *** Process received signal *** [n2c2-13:09768] Signal: Floating point exception (8) [n2c2-13:09768] Signal code: (-6) [n2c2-13:09768] Failing at address: 0x38ae800002628 [n2c2-13:09768] [ 0] /lib64/libc.so.6(+0x35670)[0x2b2705a90670] [n2c2-13:09768] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x2b2705a905f7] [n2c2-13:09768] [ 2] /lib64/libc.so.6(+0x35670)[0x2b2705a90670] [n2c2-13:09768] [ 3] /lib64/libm.so.6(+0x78b0)[0x2b270554a8b0] [n2c2-13:09768] [ 4] /home/svachha/OpenFOAM/svachha-v1706/platforms/linux64GccDPInt32Opt/lib/liblagrangianIntermediate.so(_ZNK4Foam23PairSpring SliderDashpotINS_14CollidingCloudINS_14KinematicCl oudINS_5CloudINS_15CollidingParcelINS_15KinematicP arcelINS_8particleEEEEEEEEEEEE10nSubCyclesEv+0x225 )[0x2b26feb9d245] [n2c2-13:09768] [ 5] /home/svachha/OpenFOAM/svachha-v1706/platforms/linux64GccDPInt32Opt/lib/liblagrangianIntermediate.so(_ZNK4Foam13PairCollis ionINS_14CollidingCloudINS_14KinematicCloudINS_5Cl oudINS_15CollidingParcelINS_15KinematicParcelINS_8 particleEEEEEEEEEEEE10nSubCyclesEv+0x119)[0x2b26febadf89] [n2c2-13:09768] [ 6] icoUncoupledKinematicParcelFoam[0x478d66] [n2c2-13:09768] [ 7] icoUncoupledKinematicParcelFoam[0x47902c] [n2c2-13:09768] [ 8] icoUncoupledKinematicParcelFoam[0x4797b3] [n2c2-13:09768] [ 9] icoUncoupledKinematicParcelFoam[0x479a57] [n2c2-13:09768] [10] icoUncoupledKinematicParcelFoam[0x421e1f] [n2c2-13:09768] [11] /lib64/libc.so.6(__libc_start_main+0xf5)[0x2b2705a7cb15] [n2c2-13:09768] [12] icoUncoupledKinematicParcelFoam[0x4237f5] [n2c2-13:09768] *** End of error message *** Last edited by shanvach; May 31, 2018 at 13:30. Reason: forgot to mention the openfoam version |
cohesionenergy, exception, floating, icouncoupledkinem, paircollision |
potentialFoam & simpleFoam crashes after snappyhexmesh [parallel execution] | pilot320 | OpenFOAM Running, Solving & CFD | 10 | November 12, 2015 16:56 |
reactingFoam crashes mysteriously | jose_rodrig | OpenFOAM Running, Solving & CFD | 9 | August 4, 2015 10:18 |
Simulation crashes early, crashes hard... | MtnRunBeachBum | OpenFOAM Running, Solving & CFD | 6 | April 22, 2015 09:27 |
flo-efd v11.0.0 crashes | YoavF | FloEFD, FloWorks & FloTHERM | 3 | June 21, 2012 12:37 |
[OpenFOAM] paraFoam crashes with channelFoam example | mgdenno | ParaView | 2 | February 5, 2011 07:46 |
