May 27, 2018, 13:40 |
rotatingWallVelocity BC with moving origin
Giovanni Caramia
Rep Power: 17 |
Hi everybody,
I'm using pimpleDyFoam to translate a cylinder deforming the mesh. I would like to have the cylinder rotating around its axis using rotatingWallVelocity BC but I'm facing the problem of specifying the origin of rotation because it is not constant and it moves as the cylinder changes its position. The attached picture shows the translation path (big circle) followed by the cylinder and the rotation around its axis I would like to impose (little circles). It is fundamentally a journal bearing. Have anyone already had this problem? Any hints? Thank you! |
March 9, 2021, 22:39 |
Icaro A. Carvalho
Rep Power: 5 |
Dear Giovanni,
Have you found the solution to this problem? I'm facing the exact same challenge. Cheers, I. |
March 10, 2021, 06:49 |
Giovanni Caramia
Rep Power: 17 |
Unfortunately not, so if you find it please post the solution here.
Cheers, Giova |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
moving the origin | simulady | CONVERGE | 1 | March 26, 2018 04:22 |
How to define moving wall rotation axis origin in Dynamic mesh | touyet | FLUENT | 1 | July 4, 2016 10:24 |
Equation for a rotating circle outside the origin | mali28 | Main CFD Forum | 0 | November 14, 2014 07:38 |
Access rotating origin of moving mesh by UDFs code | phanh | Fluent UDF and Scheme Programming | 0 | August 6, 2013 06:04 |
