Problem in simulation
Old   May 27, 2018, 07:27
Default Problem in simulation
Chayanit Nigaltia
CHAYANIT is on a distinguished road
I did simulation on an airfoil .Initially upto 0.2 seconds it ran perfectly but after that the simulation stopped because the courant number increases far above 1.Why might be the reason of courant number increase??
CHAYANIT is offline   Reply With Quote
Old   May 27, 2018, 23:29
Cool
sktsang is on a distinguished road
I also have similar problem. What I was modeling were intake manifolds for car engines. I use 3d mesh, with tetrahedral elements and penta elements for boundary layers, and triangle and quadrilateral shell meshes for walls and openings. When I start the simulation OpenFOAM already reported max Courant Number something like 20 or even 373 (!) (min Courant number around 0.1 looks ok). The calculation blows up very soon. I have tried remeshing the model but it's still the same.
What is funny is that the same 3d mesh does not have problems in Abaqus CFD run, in Abaqus CFD it just run perfectly no matter I use Spalart or k epsilon model although it takes a bit longer time (I keep the default 0.45 Courant number as what Abaqus suggested).
I have read the other sources online, on setting the nCorrectors, nOuterCorrectors, whatever, but it still keep on blowing up very soon. OpenFOAM is strange to me ...
sktsang is offline   Reply With Quote
Problem with wall surface reaction simulation in Fluent suren1992 CFD Freelancers 1 June 7, 2018 05:14
Contact simulation Problem nguyenthanhctm FLUENT 0 December 19, 2013 09:21
SimpleFoam convergence problem with really simple simulation mayank.dce2k7 OpenFOAM Running, Solving & CFD 2 November 19, 2013 06:28
Low pressure de Laval simulation convergence problem heksel8i FLUENT 3 July 22, 2013 11:28
Large-scale simulation problem Purushothama Main CFD Forum 0 November 7, 2010 21:12
