Error problem while running sadia d lts tutorial |
May 25, 2018, 06:16 |
Jung da yoon
Rep Power: 9 |
Hello All.
I tried to solve Sadia D LTS tutorial in combustion and used my customized solver that is reactingFoam including radiation. But while running the case, there were some errors. But I don't know what errors mean. So What do these errors mean?? I will upload my solver and case file. Please check it. Errors are following. Code:
[dayoon15@master SandiaD_LTS]$ ./Allrun Running chemkinToFoam on /home/dayoon15/OpenFOAM/dayoon15-5.0/run/tutorials/SandiaD_LTS Running blockMesh on /home/dayoon15/OpenFOAM/dayoon15-5.0/run/tutorials/SandiaD_LTS Running setFields on /home/dayoon15/OpenFOAM/dayoon15-5.0/run/tutorials/SandiaD_LTS writeInterval 1500; endTime 1500; chemistry off; Running reactingFoamRadiation on /home/dayoon15/OpenFOAM/dayoon15-5.0/run/tutorials/SandiaD_LTS writeInterval 100; endTime 7000; chemistry on; Running reactingFoamRadiation on /home/dayoon15/OpenFOAM/dayoon15-5.0/run/tutorials/SandiaD_LTS /opt/OpenFOAM/OpenFOAM-5.0/bin/tools/RunFunctions: line 53: 32365 Floating point exception(core dumped) $APP_RUN "$@" > log.$LOG_SUFFIX 2>&1 |
May 26, 2018, 04:05 |
Jung da yoon
Rep Power: 9 |
Hello All!
This is the additional error in log file Code:
Radiation solver iter: 1 DILUPBiCG: Solving for ILambda_26_0, Initial residual = 2.00187357e-05, Final residual = 1.237907894e-07, No Iterations 2 DILUPBiCG: Solving for ILambda_27_0, Initial residual = 2.00187357e-05, Final residual = 1.237907894e-07, No Iterations 2 Radiation solver iter: 2 DILUPBiCG: Solving for ILambda_26_0, Initial residual = 1.990152483e-05, Final residual = 1.419890202e-07, No Iterations 2 DILUPBiCG: Solving for ILambda_27_0, Initial residual = 1.990152483e-05, Final residual = 1.419890202e-07, No Iterations 2 T gas min/max 291, 2005.568018 DICPCG: Solving for p, Initial residual = 0.1277728175, Final residual = 0.0007597201632, No Iterations 5 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.657418346e-06, global = -1.122765535e-06, cumulative = 1.387308062e-05 p min/max = -53966.3405, 111649.0945 DICPCG: Solving for p, Initial residual = 0.03307128679, Final residual = 8.866427835e-07, No Iterations 19 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 5.144890466e-09, global = -4.963488837e-10, cumulative = 1.387258428e-05 p min/max = -33498.53976, 152245.6576 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib64/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::operator/<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&) at ??:? #5 Foam::compressibleTurbulenceModel::phi() const at ??:? #6 Foam::RASModels::kEpsilon<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::correct() at ??:? #7 ? at ??:? #8 __libc_start_main in "/lib64/libc.so.6" #9 ? at ??:? "log.reactingFoamRadiation" 3676333L, 395764593C 3676333,1 Bot |
May 26, 2018, 04:38 |
Jung da yoon
Rep Power: 9 |
Hello all
this is my 0 and system file |
OFv1606+ - Error in running the channel395DFSEM tutorial | rob3rt 0ng | OpenFOAM Running, Solving & CFD | 4 | May 27, 2017 12:00 |
Problem in running tutorial cases | preetham | OpenFOAM Installation | 2 | June 13, 2009 17:36 |
Compilation Error when running Tutorial 2.4 | zhihuali | Siemens | 7 | April 1, 2008 08:34 |
Running Tutorial Eulerian Granular Heat file | Femi | FLUENT | 0 | March 8, 2007 13:01 |
Tutorial is not running on star-CD version 3.2 | Arnab | Siemens | 0 | August 30, 2004 16:43 |
