SprayFoam Lagrange Particles Heat Transfer Fails |
May 25, 2018, 06:13 |
Ace Ventura
Rep Power: 9 |
Hello there,
as I am fairly new to the forum I hope that this is not a too easy question, but I have been stuck on this for a while now. Basically, I am simulating a liquid drop injection into slowly moving air. The air has a temperature of 295 K and the injected droplets only 285 K. I expect that this difference slowly vanishes as the droplets proceed. But, instead my particles (especially the small ones) heat up to over 350 K. Also Cp should be in the range of 1200 but the hot droplets have a Cp value of over 2100. I am using OpenFOAM-5-dev, sprayFoam, and the RanzMarshall heatTransferModel. When I turn the heatTransferModel off, the droplet temperature stays constant at 285K. Thank you very much for any hint in the right direction or ideas on how to solve this ? |
lagrange particle, openfoam, sprayfoam |
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 06:43 |
Interphase mass transfer of a reaction | cfx_ws1992 | Main CFD Forum | 0 | May 15, 2017 22:42 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
Question about heat transfer simulation | Anna Tian | Main CFD Forum | 0 | January 25, 2013 19:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
