Add calculation of drag in a solver
Old   May 23, 2018, 13:18
Default Add calculation of drag in a solver
EdP
Eduardo
EdP is on a distinguished road
Hi everyone,
I'm doing a project in college with OpenFoam5.0 about cargo ship and I need to calculate the ship's drag, but I'm can't find where put the function. I'd like to know where (what folder) I put the drag function to realize the calculates. I'm using the solver DTCHull from tutorials InterFoam
EdP is offline   Reply With Quote
Old   May 24, 2018, 03:07
Andreas P.
AndreasPe is on a distinguished road
Forces can be calculated with the "forces" and the typical drag and lift coefficients with the "force coefficients" function object. See for example this documentation:
https://www.openfoam.com/documentati...es-forces.html
https://www.openfoam.com/documentati...ce-coeffs.html
These function objects should exist in any openfoam version. Just add it in your controlDict and the results will be written in the log file as well as in a seperate file if you wish.
AndreasPe is offline   Reply With Quote
Hybrid discretisation - blend factor gcoopermax CFX 5 September 23, 2016 09:05
Wall component calculation using foamCalc vs Solver Bernhard OpenFOAM Post-Processing 5 February 15, 2014 16:30
How to add Radiation to existing buoyantBoussinesqSimpleFoam solver MasAmi OpenFOAM Running, Solving & CFD 4 January 16, 2014 07:17
Calculation of Drag Coefficient manually PRASHANT GHADGE FLUENT 4 December 13, 2012 16:31
Warning 097- AB Siemens 6 November 15, 2004 05:41
