adjointShapeOptimizationFoam - inlet velocity weird behavior
Old   May 23, 2018, 12:26
Default adjointShapeOptimizationFoam - inlet velocity weird behavior
C. Okubo is on a distinguished road
Hi!
People using adjointShapeOptimizationFoam, have you ever noticed that the adjoint velocity vectors of the very first line of cells are usually pointing to an akward direction? I mean, I know adjoint velocity is not phisically something we can interpret, but this behavior is really strange to me. I would expect something more continuous. Seems like some discontinuity, source or something is acting. Please, see figure 1 of an example (this is the first iteration of an example I am running).
The left faces are the inlet of my domain (the only faces with arrows) and vectors are adjoint velocity field. Note that, for the next cells (second column from left to right), things seem to be back to expected behaviour. So, when this velocities are weird (as the picture), as sensitivities are scalar product of both fields (primal and adjoint), the method starts to block the entrance cells and that is where the problem starts: adjoint field diverges and I can't get a clean solution.
The original code removes the Adjoint Transpose Convection at inlet cells, but this is not exactly OK and I am trying to not use this.
Note: all examples shown here were generated with the ATC being calculated in the whole domain, so I am not removing it.
Something interesting I found out is that, when I use relaxation factors below, I get the result from figure 1.
pa = 0.3
Ua = 0.7
But, if I invert them:
pa = 0.7
Ua = 0.3
Then, I have figure 2, which is more according to what is expected.
Even though I am being able to have good results using cell limiters on grad(Ua), I think the best I could have until now is with the use of the flow rate inlet BC and relaxation factors higher for pa than Ua. Please, see BC example below and figure 3 of the same case (without grad limiter or removal of ATC).
inlet
type flowRateInletVelocity;
massFlowRate 0.01;
value uniform (0 0 0);
rhoInlet 1.0;
extrapolateProfile yes;
This last combination (relaxation factor + flow rate at inlet) gives a clean solution without removal of ATC.
I would really appreciate any comments of the more experienced people on this.
Best Regards,
Okubo
C. Okubo is offline   Reply With Quote
Old   May 23, 2018, 12:30
Forgot the figures!
3-D parabolic velocity Inlet - Steady state - UDF Turbulent Flow mohibanwar Fluent UDF and Scheme Programming 10 May 18, 2015 11:34
UDF: Change boundary condition. Velocity inlet to pressure inlet at time "t" jpina FLUENT 10 April 11, 2015 15:19
velocity inlet and ideal gas simultaneously-what's wrong? preetam69 FLUENT 0 September 28, 2013 05:51
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 12:21
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
