Initial time step will have effects on LES result? |
May 21, 2018, 09:44 |
Jingxue Wang
Rep Power: 9 |
Hello,every one!
I use LES to calculate the wind pressure on roof-mounted solar panels. Before,I calculated the wind pressure results of LES using previous 6s(from 4s to 10s). The mean and STD statistics values are very close to wind tunnel test. I continue to calculate to get more longer data(from 10s to 20s). But the results of next calculation is too bad and have much difference with experiment results.I am so curious about this. I can not figure out the reason. The only one probable reason that I can think is the initial time step will have effects on this? The second stage calculation starts at the latestTime time step of the first stage calculation. I hope can get any suggestion and help!Thanks |
May 21, 2018, 10:51 |
Uwe Pilz
Rep Power: 15 |
If your simulation doesn't crash, you eventual get a pseudo steady state result. This result should not depend (very strongly) from the initial conditions. But it depends strongly on the boundary conditions.
Using a developed flow as starting point, the first time steps however, depend strongly on this flow but to a lesser degree on boundary conditions. From my experience it is note easy (and often quite hard) to establish adequate b.c. I don't think that you may learn that to a high level from text books. You need experience, which is invaluable.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
May 21, 2018, 14:18 |
#3 | |
Santiago Lopez Castano
Rep Power: 16 |
p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 16:53 |
time step continuity problem in VAWT simulation | lpz_michele | OpenFOAM Running, Solving & CFD | 5 | February 22, 2018 20:50 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 19:17 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 11:08 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
