Wingtip vortex OpenFoam. Error solving with simpleFoam
Old   May 16, 2018, 15:08
Default Wingtip vortex OpenFoam. Error solving with simpleFoam
luram94 is on a distinguished road
Hi foamers.
I am simulating a wingtip vortex for a laminar, steady case.
I have adapted the Airfoil2D tutorial to my 3D case.
I am using a simulation type laminar that i've typed on the turbulenceProperties file.
My mesh is a wing of 0.1 chord enclosed on a prism. I've meshed it with PointWise.
I have checked the smallest cell of my mesh to adapt the deltaT for the courant number. The smallest cell size is "Minimum face area = 1.4231e-09". So I am trying different deltaT values but the error always happens on the same point.
Here you can see the mistake.
I hope someone could help me.
Thank you !!
luram94@Aspire-E5-574G:~/OpenFOAM/luram94-5.0/run/airFoil2D1$ simpleFoam
| \\ / O peration | Version: 5.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 5.x-197d9d3bf20a
Exec : simpleFoam
Date : May 16 2018
Time : 19:45:59
Host : "Aspire-E5-574G"
PID : 5766
I/O : uncollated
Case : /home/luram94/OpenFOAM/luram94-5.0/run/airFoil2D1
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
field p tolerance 1e-05
field U tolerance 1e-05
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
No MRF models present
No finite volume options present
Starting time loop
Time = 0.0001
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0695286, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0254532, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.0654825, No Iterations 4
GAMG: Solving for p, Initial residual = 1, Final residual = 0.0943924, No Iterations 16
time step continuity errors : sum local = 9.32871e-09, global = -1.09984e-20, cumulative = -1.09984e-20
ExecutionTime = 0.24 s ClockTime = 0 s
Time = 0.0002
smoothSolver: Solving for Ux, Initial residual = 0.417036, Final residual = 0.0237835, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.525095, Final residual = 0.0355146, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.361729, Final residual = 0.0187467, No Iterations 4
GAMG: Solving for p, Initial residual = 0.994142, Final residual = 0.0944352, No Iterations 4
time step continuity errors : sum local = 2.68322e-07, global = -6.64015e-21, cumulative = -1.76385e-20
ExecutionTime = 0.32 s ClockTime = 0 s
Time = 0.0003
smoothSolver: Solving for Ux, Initial residual = 0.48106, Final residual = 0.0291823, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.592922, Final residual = 0.0163415, No Iterations 6
smoothSolver: Solving for Uz, Initial residual = 0.365147, Final residual = 0.0195021, No Iterations 4
GAMG: Solving for p, Initial residual = 0.989267, Final residual = 0.098107, No Iterations 65
time step continuity errors : sum local = 6.09575e-06, global = -2.51469e-21, cumulative = -2.01532e-20
ExecutionTime = 0.61 s ClockTime = 0 s
Time = 0.0004
smoothSolver: Solving for Ux, Initial residual = 0.633188, Final residual = 0.0383804, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.631868, Final residual = 0.0342176, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.544371, Final residual = 0.0420833, No Iterations 2
GAMG: Solving for p, Initial residual = 0.99557, Final residual = 0.0985544, No Iterations 22
time step continuity errors : sum local = 0.000284088, global = -7.5344e-20, cumulative = -9.54973e-20
ExecutionTime = 0.74 s ClockTime = 0 s
Time = 0.0005
smoothSolver: Solving for Ux, Initial residual = 0.503184, Final residual = 0.0360833, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.600972, Final residual = 0.0378856, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.580002, Final residual = 0.0347582, No Iterations 4
GAMG: Solving for p, Initial residual = 0.999452, Final residual = 0.0939822, No Iterations 17
time step continuity errors : sum local = 0.00724173, global = 6.35417e-19, cumulative = 5.39919e-19
ExecutionTime = 0.86 s ClockTime = 0 s
Time = 0.0006
smoothSolver: Solving for Ux, Initial residual = 0.494103, Final residual = 0.013902, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.45221, Final residual = 0.0124333, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.506377, Final residual = 0.0317716, No Iterations 4
GAMG: Solving for p, Initial residual = 0.992318, Final residual = 0.0991528, No Iterations 21
time step continuity errors : sum local = 0.191447, global = 6.35768e-18, cumulative = 6.8976e-18
ExecutionTime = 1 s ClockTime = 1 s
Time = 0.0007
smoothSolver: Solving for Ux, Initial residual = 0.524298, Final residual = 0.0290546, No Iterations 6
smoothSolver: Solving for Uy, Initial residual = 0.525085, Final residual = 0.0402515, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.929924, Final residual = 0.0688259, No Iterations 10
GAMG: Solving for p, Initial residual = 0.999893, Final residual = 0.0971346, No Iterations 10
time step continuity errors : sum local = 29.8918, global = -5.18405e-15, cumulative = -5.17715e-15
ExecutionTime = 1.1 s ClockTime = 1 s
Time = 0.0008
smoothSolver: Solving for Ux, Initial residual = 0.549428, Final residual = 0.0525383, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.535445, Final residual = 0.00941288, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.485405, Final residual = 0.00742206, No Iterations 4
GAMG: Solving for p, Initial residual = 0.89532, Final residual = 0.0826279, No Iterations 3
time step continuity errors : sum local = 294.428, global = -6.74072e-14, cumulative = -7.25843e-14
ExecutionTime = 1.16 s ClockTime = 1 s
Time = 0.0009
smoothSolver: Solving for Ux, Initial residual = 0.538549, Final residual = 0.0375504, No Iterations 6
smoothSolver: Solving for Uy, Initial residual = 0.572799, Final residual = 0.0172758, No Iterations 8
smoothSolver: Solving for Uz, Initial residual = 0.47479, Final residual = 0.0266104, No Iterations 8
GAMG: Solving for p, Initial residual = 3.30709e-05, Final residual = 2.99641e-06, No Iterations 12
time step continuity errors : sum local = 7.49553e+06, global = 1.44336e-08, cumulative = 1.44335e-08
ExecutionTime = 1.27 s ClockTime = 1 s
Time = 0.001
smoothSolver: Solving for Ux, Initial residual = 0.466723, Final residual = 0.0230642, No Iterations 46
smoothSolver: Solving for Uy, Initial residual = 0.471586, Final residual = 0.0297526, No Iterations 42
smoothSolver: Solving for Uz, Initial residual = 0.37227, Final residual = 0.0159206, No Iterations 48
GAMG: Solving for p, Initial residual = 1, Final residual = 0.0966592, No Iterations 6
time step continuity errors : sum local = 4.40691e+16, global = -60.8033, cumulative = -60.8033
ExecutionTime = 1.42 s ClockTime = 1 s
Time = 0.0011
smoothSolver: Solving for Ux, Initial residual = 0.400004, Final residual = 177.261, No Iterations 1000
smoothSolver: Solving for Uy, Initial residual = 0.428658, Final residual = 285.171, No Iterations 1000
smoothSolver: Solving for Uz, Initial residual = 0.445417, Final residual = 649.365, No Iterations 1000
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
#4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
#8 Foam::fvMatrix<double>::solve() at ??:?
#9 ? at ??:?
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11 ? at ??:?
luram94 is offline   Reply With Quote
Old   October 19, 2018, 12:53
Klaus
klausb will become famous soon enough
it's usually worth to try a tolerance for p lower than that of the other values e.g.
solvers
    p
        solver                PCG;
        preconditioner   FDIC;
        tolerance           1e-08;
        relTol                0;
    U
          solver                PBiCGStab;
          preconditioner   DILU;
          tolerance           1e-7;
           relTol                 0.01;
But actually to give real advice, you should provide more information about your mesh including the number of cells around your airfoil (try 300 cells chord wise) and the other mesh parameters used. Did you use checkMesh and renumberMesh? How many cells are there?
What's your AOA, reynolds number etc.?
Could you post your case or at least some key files including fvSolution, fvSchemes and controlDict?
The setup of the airFoil2D case appears rather "minimalistic" especially the fvSchemes.
klausb is offline   Reply With Quote
laminar flow, simplefoam, solve, solve time, wingtip
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 06:40
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
wingtip vortex Rooney Siemens 2 January 9, 2009 08:58
