Using multiInteraction type patchInteractionModel |
May 16, 2018, 03:44 |
SURAJ
Rep Power: 9 |
Hi
I am using MPPICFoam,I am simulating a riser of circulating fluidised bed. Which consists of cylindrical geometry Inlet at the bottom,Outlet at top and circular wall. In which I have first distributed the particle by using injectionModel of type manualinjection and difined the particle positions initially. Now,What I have to do is insert the same number of particles in the inlet patch which is coming out of the Outlet patch. I searched and found that by using multiInteraction we can apply multiple patchintraction models at a time.I applied the multiInteraction patch intraction model as per the instruction in PatchInteractionModel.H but found following error. ----------------------------------------------------------------------------------- Unknown patch interaction model type coincidentBaffleInteraction Valid patch interaction model types are: 5 ( localInteraction multiInteraction none rebound standardWallInteraction ) ---------------------------------------------------------------------------------- Can anybody tell what is coincidentBaffleInteraction. Or how to apply cyclic type boundary condition for the particle phase onle by using this this patch intraction type. |
June 22, 2019, 20:53 |
spike
Rep Power: 7 |
hi surajkvs
You could find information on how to use multi interaction to solve your problem? I have a similar problem Thank you |
multiinteraction, patchinteractionmodel |
activeBaffleVelocity boundary condition ? | om3ro | OpenFOAM Programming & Development | 10 | November 17, 2020 00:26 |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 01:21 |
rhoPimpleFoam hardship | petrus | OpenFOAM Running, Solving & CFD | 0 | October 7, 2016 03:41 |
interFoam/kOmegaSST tank filling with printStackError/Mules | simpomann | OpenFOAM Running, Solving & CFD | 3 | February 17, 2014 18:06 |
[swak4Foam] Air Conditioned room groovyBC | Sebaj | OpenFOAM Community Contributions | 7 | October 31, 2012 15:16 |
