1D Modelling of Mechanical Ventilation Network in OpenFOAM |
May 15, 2018, 09:12 |
Rep Power: 8 |
I am running a fire simulation in a compartment and I would like to implement a ventilation model for the mechanical ventilation system.. I would like to use multiscale modelling method which means that I would represent the ventilation network with a 1D model. I am still a beginner with OpenFOAM and I would like to develop a 1D model for the ventilation network. Is that possible solely with OpenFOAM or woud I have to use another software to implement a 1D model and couple it with OpenFOAM. |
May 16, 2018, 00:51 |
Uwe Pilz
Rep Power: 15 |
In general, OF works with 3d (unavoidable). There exist a b.c. to reduce the complexity to 2 or (rarely used) 1 dimensions: empty. You need to use only 1 element in the dimension(s) you wish to suppress.
There are many examples for 2D, from which you may learn how to set an 1D geometry.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
May 16, 2018, 07:51 |
Rep Power: 8 |
@piu58: Thanks for your reply. Where can I find the examples for the 2D. Are they the ones in OpenFOAM tutorials? Am guessing it will still be possible to set a boundary condition that I would be using in the 1D model. When you say i need to only use 1 element in the dimensions I wish to suppress, am guessing you mean during setting up by mesh right?
Best regards |
May 16, 2018, 08:17 |
Uwe Pilz
Rep Power: 15 |
Yes, I meant these. > only use 1 element in the dimensions I wish to suppress, am guessing you mean during setting up by mesh right? yes.
May 16, 2018, 10:25 |
Rep Power: 8 |
Thanks a lot.
Is it also possible to create a solver that can solve the 1D geometry in OpenFOAM using the governing equations but for one dimensional case. Thanks. |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
Modelling a Canopy in OpenFOAM | jhart3000 | OpenFOAM | 0 | November 29, 2016 14:09 |
Portable openFOAM on Windows (7) school network | peterfagg | OpenFOAM Installation | 2 | January 24, 2013 03:28 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
