alpha value is negative
Old   May 7, 2018, 06:46
Default alpha value is negative
L S
silviliril is on a distinguished road
I am trying to simulate condensation problem using phaseChangeHeatFoam using Dynamic Mesh. But, I am getting following error. Where Value of alpha is going -751. WHich is non physical.
Create time
Create mesh for time = 0.001
Selecting dynamicFvMesh dynamicRefineFvMesh
Reading field p_rgh
Reading field T
Reading field alpha1
Reading field U
Creating phaseChangeTwoPhaseMixture
Selecting phaseChange model Hardt
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Reading g
Reading hRef
Calculating field g.h
No finite volume options present
Creating field kinetic energy K
PIMPLE: Operating solver in PISO mode
time step continuity errors : sum local = 0, global = 0, cumulative = 0
GAMGPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
Courant Number mean: 0 max: 0
Starting time loop
Interface Courant Number mean: 0 max: 0
deltaT = 0.001
Time = 0.002
Selected 20000 cells for refinement out of 1285000.
Refined from 1285000 to 1425000 cells.
Selected 0 split points out of a possible 20000.
Execution time for mesh.update() = 9.29 s
time step continuity errors : sum local = 0.63639, global = 6.51141e-17, cumulative = 6.51141e-17
GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 7.59271e-05, No Iterations 4
time step continuity errors : sum local = 4.83193e-05, global = -1.52192e-06, cumulative = -1.52192e-06
MULES: Solving for alpha1
Liquid phase volume fraction = 0.495664 Min(alpha1) = -751.483 Max(alpha1) = 616.829
Liquid phase volume fraction = 0.746649 Min(alpha1) = -562573 Max(alpha1) = 570996
Liquid phase volume fraction = -79.9499 Min(alpha1) = -1.04484e+09 Max(alpha1) = 4.82987e+08
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 911.698, No Iterations 1001
DILUPBiCG: Solving for Uy, Initial residual = 0.918964, Final residual = 5515.72, No Iterations 1001
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 49428.4, No Iterations 1001
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
#4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
at ??:?
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
Floating point exception (core dumped)
fvschemes:
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    div(rho*phi,U)  Gauss upwind;
    div(rhoPhi,U)  Gauss vanLeerV;
    div(phi,T)  Gauss vanLeer;
    div(rhoPhi,T)    Gauss  vanLeer;
    div(phi,alpha)  Gauss vanLeer01;
    div(phirb,alpha) Gauss interfaceCompression;
    div((muEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p_rgh;
    pcorr;
    alpha;
fvsolution:
solvers
    alpha1
        maxUnboundedness 1e-5;
        CoCoeff          2;
        maxIter          5;
        nLimiterIter     2;
        solver           PBiCG;
        preconditioner   DILU;
        tolerance        1e-12;
        relTol           0.01;
 "(U|UFinal|T|TFinal)"
        solver           PBiCG;
        tolerance        1e-06;
        relTol           0;
 "(p_rgh|p)"
        solver          PCG;
	preconditioner
            preconditioner  GAMG;
            tolerance       1e-08;
            relTol          0;
            nVcycles        2;
            smoother        GaussSeidel;
            nPreSweeps      0;
            nPostSweeps     2;
            nFinestSweeps   2;
            cacheAgglomeration true;
            nCellsInCoarsestLevel 10;
            agglomerator    faceAreaPair;
            mergeLevels     1;
        tolerance       1e-08;
        relTol          0.001;
        maxIter         20;
    pcorr
        solver          PCG;
        preconditioner
            tolerance       0.001;
            relTol          0;
            nPreSweeps      0;
            nPostSweeps     2;
            nFinestSweeps   2;
            cacheAgglomeration false;
            mergeLevels     1;
        tolerance       0.0001;
        relTol          0;
        maxIter         100;
    "(p_rghFinal|pFinal)"
        solver          PCG;
        preconditioner
            tolerance       1e-08;
            relTol          0;
            nVcycles        2;
            nPreSweeps      2;
            nPostSweeps     0;
            nFinestSweeps   2;
            mergeLevels     1;
        tolerance       1e-08;
        relTol          0;
    p_rgh
        solver          GAMG;
        tolerance       1e-08;
        relTol          0.05;
        nPreSweeps      0;
        nPostSweeps     2;
        nFinestSweeps   2;
        mergeLevels     1;
    p_rghFinal
        solver          PCG;
        preconditioner
            tolerance       1e-08;
            relTol          0;
            nVcycles        2;
            nPreSweeps      0;
            nPostSweeps     2;
            nFinestSweeps   2;
            mergeLevels     1;
        tolerance       1e-08;
        relTol          0;
        maxIter         20;
    U
        solver          smoothSolver;
        tolerance       1e-06;
        relTol          0;
        nSweeps         1;
    "(k|B|nuTilda)"
        solver          PBiCG;
        tolerance       1e-08;
        relTol          0;
  /* T   //add
        solver           PBiCG;
        tolerance        1e-10;
        relTol           0;
  /*TFinal   //added
        solver           PBiCG;
        tolerance        1e-10;
        relTol           0;
  "(T|TFinal)"
        solver           PBiCG;
        tolerance        1e-10;
        relTol           0;
    rho   //add
        solver           Diagonal;
        tolerance        1e-8;
        relTol           0;
relaxationFactors
    T       0.3
    U       0.3
    p       0.3;
"(PISO|PIMPLE)"
    momentumPredictor yes;
    nCorrectors     3;
    nNonOrthogonalCorrectors 0;
    nAlphaCorr      1;
    nAlphaSubCycles 3;
    cAlpha          1;
    pRefPoint      (0.51 0.51 0.51);
    pRefValue      0;
 smoothItr                  2;
    kSmoothItr                 0;
silviliril is offline   Reply With Quote
Old   May 18, 2018, 09:44
L S
I got the solution. I just reduced the value of deltaT from 0.001 to 0.000001.
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
