How to resolve boundary layer in OF ?
Old   May 3, 2018, 18:01
Default How to resolve boundary layer in OF ?
Blue8655's Avatar
Blue8655 is on a distinguished road
I tend to use high Reynolds wall functions in my simulations, but I'm in a case where it seems more appropriate to resolve the boundary layer. However, I don't know how to do this in OpenFOAM, I just don't know what boundary condition to use for solid walls. At first I thought I should use:
type fixedValue;
value uniform 0.01;
for k, epsilon and nut, but the simulation crashes or provides poor result. Moreover, I don't understand how some authors seem to avoid the use of wall functions, since (Launder and Spalding,74) say that the k-epsilon model is not defined near walls... An example of authors who solve the boundary in OF would be: " (Limane et al. 2015) Thermo-ventilation study by OpenFOAM of the airflow in a cavity with heated floor". They don't mention the BC used though.
Some people** talk about low-Re turbulence models but (Limane,2015) used buoyantSimpleFoam and other "regular" models (BSF, BPF, and BBPF) while keeping y+<11. So I'm quite confused right now!!
Any help appreciated! Pointing me to an older post is good too. I use OF-3.0.1. Thanks you very much.
**Solving boundary layer with k-e model
Blue8655 is offline   Reply With Quote
Old   May 4, 2018, 01:47
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
A wall is connected to wall functions, a patch is not. If you use patches at the boundaries, you may left out the wall functions without problems.
For an accurate result you need to resolve the boundaries down to the region y+=1, combined with very small time steps. Or in other words: You need to calculate a DNS simulation.
Another way would be to work with LES models and wall functions. If you use finer and finer meshes, more and more of the turbulence is calculated directly. But you have the wall function as a kind of safeguard.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   May 4, 2018, 11:36
Blue8655's Avatar
Thank you for reply Uwe. If I get you right... you are telling me that if in polyMesh/boundaries, I use 'patch' instead of 'wall' for those solid surfaces, my simulation will behave much better ? I never would have thought about this! I will try it soon.
P.S. Stupid question, but how can I search for an exact expression in the CFD-online forum ? (e.g. "wall function")
Old   May 4, 2018, 14:06
piu58's Avatar
Uwe Pilz
'Much better' in the sense 'close to that what you wish.
It may be however, that wall functions give a amore reliable result (if you cannot afford the spatial and time resolution you need).
Uwe Pilz
Old   May 6, 2018, 19:59
Blue8655's Avatar
I tested your suggestion Piu58. It works. Using y+<1, flow behavior is coherent.
At first, OF complained about a wall function still present for alphaT.
( type compressible::alphatWallFunction; )
I used "calculated" instead, as for inlet and outlet. Worked.
I agree with your comment though that in most cases I will continue to use wall functions to limit computational requirements.
Thanks for your help. Much appreciated.
boundary layer., lrn, openfoam, resolve
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 09:26
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
