3D Thrust Vectoring Nozzle rhoCentralFoam problem |
May 1, 2018, 06:00 |
Alejandro
Hello everyone,
I'm working on my final bachelor degree thesis and I could use some help. I'm running a simulation using rhoCentralFoam for a mesh I did in pointwise. Here are my BCs for p,T,U p boundaryField { Inlet { type totalPressure; gamma 1.4; p0 uniform 8.25; } Boxin { type zeroGradient; } Walls { type zeroGradient; } Box { type fixedValue; value uniform 1; } Boxout { type fixedValue; value uniform 1; } } T internalField uniform 2.75; boundaryField { Inlet { type totalTemperature; gamma 1.4; T0 uniform 2.75; } Walls { type zeroGradient; } Boxin { type zeroGradient; } Box { type zeroGradient; } Boxout { type zeroGradient; } } U internalField uniform (0 0 0); boundaryField { Inlet { type zeroGradient; } Walls { type noSlip; } Boxin { type slip; } Box { type zeroGradient; } Boxout { type zeroGradient; } } This are the thermophysical properties and turbulence prop. thermoType { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } mixture { specie { nMoles 1; molWeight 8314.472; } thermodynamics { Cp 29.1; Hf 0; } transport { mu 0; Pr 1; } } } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // simulationType laminar; // ************************************************** *********************** // And now controldict,fv schemes and solution application rhoCentralFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 30; deltaT 1e-6; writeControl adjustableRunTime; writeInterval 0.1; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; adjustTimeStep yes; maxCo 0.6; maxDeltaT 1; fluxScheme Kurganov; ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { default none; div(tauMC) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; reconstruct(rho) vanAlbada; reconstruct(U) vanAlbadaV; reconstruct(T) vanAlbada; } snGradSchemes { default corrected; } solvers { "(rho|rhoU|rhoE)" { solver diagonal; } U { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 0; relTol 0; } h { $U; tolerance 0; relTol 0; } } By establishing the pressure difference between inlet and outlet (exterior) I aim to set several nozzle regimes to study the flow but when the pressure difference it's too big I always get this error. [0] #0 Foam::error:rintStack(Foam::Ostream&) at ??:? [0] #1 Foam::sigFpe::sigHandler(int) at ??:? [0] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [0] #3 Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) at ??:? [0] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::sqrt<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&) at ??:? [0] #5 ? at ??:? [0] #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [0] #7 ? at ??:? [Aspire-F5-573G:18398] *** Process received signal *** [Aspire-F5-573G:18398] Signal: Floating point exception (8) [Aspire-F5-573G:18398] Signal code: (-6) [Aspire-F5-573G:18398] Failing at address: 0x3e8000047de Please can someone help me? I'm so stuck and I need to fix my problem. I attach my main folders. Thank you so much. You can see the mesh in the attached image. Alex |
May 3, 2018, 16:43 |
Help
Alejandro
Please I really need help with this error.
[0] #0 Foam::error:rintStack(Foam::Ostream&) at ??:? [0] #1 Foam::sigFpe::sigHandler(int) at ??:? [0] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [0] #3 Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) at ??:? [0] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::sqrt<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&) at ??:? [0] #5 ? at ??:? [0] #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [0] #7 ? at ??:? [Aspire-F5-573G:18398] *** Process received signal *** [Aspire-F5-573G:18398] Signal: Floating point exception (8) [Aspire-F5-573G:18398] Signal code: (-6) [Aspire-F5-573G:18398] Failing at address: 0x3e8000047de |
Problem with nozzle analysis | Aristine | Main CFD Forum | 0 | March 15, 2012 07:28 |
Always crash when solve a C-D nozzle flow field using rhoCentralFoam | hawklion | OpenFOAM Running, Solving & CFD | 0 | March 9, 2011 06:13 |
Always crash when solve a C-D nozzle flow field using rhoCentralFoam | hawklion | OpenFOAM | 3 | March 8, 2011 19:03 |
Convergence Problem Supersonic Flow Laval Nozzle | Tobias | CFX | 3 | December 7, 2005 01:23 |
compressible flow in a counterflow nozzle | d.vamsidhar | FLUENT | 0 | November 24, 2005 01:45 |
