fluctuation in force coefficients with dynamicTopoFvMesh |
May 1, 2018, 03:55 |
Rep Power: 10 |
Hello
i want to simulate pitching and plunging airfoil with large amplitude in ground effect. because of large amplitude i use remeshing with dynamicTopoFvMesh. first i simulate pitching and plunging airfoil out of ground effect. airfoil movement and remeshing is very good but when i active flow solver (pimpleDyMFoam), forces coeff (cl , cd) have fluctuations. i solve this problem with dynamicFvMesh and compare result with kinsey and dumas, the results had very good agreement. then i simulate that problem with remeshing dynamicTopoFvMesh that results have fluctuation. in both solver initial and boundary conditions are the same and flow solver is pimpleDyMFoam or icoDyMFoam with foam extend 3.1. i examine different scheme, time step , ... but no effect on fluctuation. what is the reason of this fluctuations? how can i remove this fluctuation? how can you help me please? thanks. |
May 1, 2018, 18:10 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answers/questions:
May 2, 2018, 04:41 |
Rep Power: 10 |
i ran the simulation in serial mode.
i set nOuterCorrectors up to 100 but after each remeshing of domain and remapping, the result show jumpping. i didn't try RBF, because i must consider the ground effect and airfoils in tandem configurations. thanks for rapid answer Bruno. |
ActuatorDiskExplicitForce in OF2.1. Help | be_inspired | OpenFOAM Programming & Development | 10 | September 14, 2018 12:12 |
Sectional force coefficients | tfuwa | OpenFOAM Post-Processing | 1 | June 27, 2013 07:49 |
[OpenFOAM] spatial distribution of force coefficients in paraview&openfoam | kkpal | ParaView | 1 | April 21, 2013 08:15 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 23:03 |
Density for calculating Force Coefficients | ste_lakey | CFX | 2 | September 19, 2005 05:35 |
