buoyantSimpleFoam : flow reverses direction unexpectedly |
Rep Power: 9 ![]() |
My case : a cylindrical pipe, ID=4.76mm, L=71mm. I mesh just a 5° wedge. Fluid = air. Velocity at inlet = 0.11m/s, Re = 35. I am trying to run buoyantSimpleFoam the most basic way : no turbulence, all temperatures set to 293K. I plot the velocity profile at the outlet, and I expect a parabolic profile. It does happen, but the velocity then reduces to 1/10 of the expected value (as far as I ran the case) and the flow changes direction near the inlet and exits the pipe trough the inlet, as can be seen in the picture bellow. I really don't know where to look, so a hint would be very welcome ! ![]() 0/U : Code:
FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0.1169496439); // 1/8 l/min boundaryField { #includeEtc "caseDicts/setConstraintTypes" inlet { type fixedValue; value uniform (0 0 0.1169496439); // 1/8 l/min } outlet { type zeroGradient; } wallPipe { type noSlip; } axis { type symmetry; } front { type wedge; } back { type wedge; } } Code:
FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1e5; boundaryField { #includeEtc "caseDicts/setConstraintTypes" inlet { type fixedValue; value uniform 1e5; } outlet { type zeroGradient; } wallPipe { type zeroGradient; } axis { type symmetry; } front { type wedge; } back { type wedge; } } Code:
FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1e5; boundaryField { #includeEtc "caseDicts/setConstraintTypes" inlet { type fixedValue; value uniform 1e5; } outlet { type zeroGradient; } wallPipe { type zeroGradient; } axis { type symmetry; } front { type wedge; } back { type wedge; } } Code:
FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 293; boundaryField { inlet { type fixedValue; // value uniform 300.15; // Ts = Tc + 17 degC value uniform 293; } outlet { type zeroGradient; } wallPipe { type fixedValue; // value uniform 283.15; // Tc = 10 degC value uniform 293; } axis { type symmetry; } front { type wedge; } back { type wedge; } } Code:
FoamFile { version 2.0; format ascii; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss limitedLinear 0.2; div(phi,K) bounded Gauss limitedLinear 0.2; div(phi,h) bounded Gauss limitedLinear 0.2; div(phi,k) bounded Gauss limitedLinear 0.2; div(phi,epsilon) bounded Gauss limitedLinear 0.2; div(phi,omega) bounded Gauss limitedLinear 0.2; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { // default Gauss linear orthogonal; default Gauss linear uncorrected; } interpolationSchemes { default linear; } snGradSchemes { // default orthogonal; default uncorrected; } /*wallDist { method meshWave; } */ Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p_rgh { solver GAMG; tolerance 1e-7; relTol 0.01; smoother DICGaussSeidel; } // "(U|h|k|epsilon|omega)" "(U|h)" { solver PBiCGStab; preconditioner DILU; tolerance 1e-8; relTol 0.1; } } SIMPLE { // momentumPredictor no; momentumPredictor yes; // to print U residuals nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; residualControl { p_rgh 1e-4; U 1e-4; h 1e-4; // possibly check turbulence fields // "(k|epsilon|omega)" 1e-3; } } relaxationFactors { fields { rho 1.0; p_rgh 0.7; } equations { U 0.3; h 0.3; // "(k|epsilon|omega)" 0.7; } } Code:
FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object thermophysicalProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } mixture { specie { molWeight 28.96; } thermodynamics { Cp 1004.4; Hf 0; } transport { mu 1.831e-05; Pr 0.705; } } Code:
FoamFile { version 2.0; format ascii; class dictionary; object RASProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // //simulationType RAS; simulationType laminar; RAS { RASModel kOmegaSST; turbulence on; printCoeffs on; } |
Joachim Herb
Rep Power: 22 ![]() |
What is the direction of gravity? Perpendicular to the flow direction? If not, you can use for the p_rgh outlet boundary condition:
fixedMean, see https://github.com/OpenFOAM/OpenFOAM...ived/fixedMean |
U and p are set at the inlet. That's OK for U, but p should be set at the outlet instead.
Mass flow "outlet" BC reverses flow after 20 iterations | swadejaxsun | STAR-CCM+ | 1 | January 31, 2018 12:57 |
Inlet flow direction at axial turbomachinery with twisted Blades | Stuntmanbob | CFX | 9 | November 9, 2015 15:17 |
High No Iterations in Secondary Flow Direction | camoesas | OpenFOAM Running, Solving & CFD | 0 | July 9, 2014 04:11 |
Bug for cylindrical components of flow direction ? | pierre victor cueille | CFX | 1 | May 2, 2006 09:37 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
