Checkerboarding on hanging nodes chtMustiRegionFoam
Old   April 26, 2018, 04:14
Default Checkerboarding on hanging nodes chtMustiRegionFoam
SeMar is on a distinguished road
Hey guys,
I recently discovered, that some of my cases show checkerboarding in hanging nodes areas. This occurs visibly only in the temperature field.
My setup is roughly the following. First I solve the (laminar) impulse equation on the fluid domain with pimpleFoam while time averaging the velocity field. Then I copy the UMean to the main case and solve the energy equation on the multi domain (1 solid, 1 fluid) with chtMultiRegionFoam until the temperature on the outlet patch does not change.
I already tried different numerical schemes and switched to first order with no visible effect. The velocity field shows no oscillatory behaviour at all. Residuals are around 1e-5.
the fvSchemes files for the fluid domain is:
ddtSchemes
    default        backward;
gradSchemes
    default         cellMDLimited Gauss linear 0.5;
    grad(U)         cellMDLimited Gauss linear 0.5;
divSchemes
    default         none;
    div(((rho*nuEff)*dev2(T(grad(U)))))  Gauss linear;
    div(phi,U)      Gauss linearUpwind grad(U);
    div(phi,h)      Gauss linearUpwind default;
    div(phi,e)      Gauss linearUpwind default;
    div(phi,K)      Gauss linearUpwind default;
laplacianSchemes
    default         Gauss linear limited 0.777;
interpolationSchemes
    default         linear;
snGradSchemes
    default         limited 0.777;
fluxRequired
    default         no;
    p_rgh;
CheckMesh output is:
Overall domain bounding box (-0.0049 -0.0035 -0.0001) (0.0091 0.0035 0.0001)
    Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
    Mesh has 3 solution (non-empty) directions (1 1 1)
    Boundary openness (2.272174e-17 1.934456e-17 -5.833666e-17) OK.
    Max cell openness = 3.444354e-16 OK.
    Max aspect ratio = 6.548118 OK.
    Minimum face area = 2.401861e-12. Maximum face area = 1.000083e-08.  Face area magnitudes OK.
    Min volume = 4.095064e-18. Max volume = 1.000069e-12.  Total volume = 1.808073e-08.  Cell volumes OK.
    Mesh non-orthogonality Max: 58.54525 average: 7.599924
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 2.60591 OK.
    Coupled point location match (average 0) OK.
    Face tets OK.
    Min/max edge length = 2.005364e-07 0.000100008 OK.
   *There are 698 faces with concave angles between consecutive edges. Max concave angle = 43.46902 degrees.
  <<Writing 698 faces with concave angles to set concaveFaces
    Face flatness (1 = flat, 0 = butterfly) : min = 0.8599798  average = 0.9989744
    All face flatness OK.
    Cell determinant (wellposedness) : minimum: 0 average: 11.76043
 ***Cells with small determinant (< 0.001) found, number of cells: 4
  <<Writing 4 under-determined cells to set underdeterminedCells
 ***Concave cells (using face planes) found, number of cells: 25139
  <<Writing 25139 concave cells to set concaveCells
    Face interpolation weight : minimum: 0.1086233 average: 0.4817486
    Face interpolation weight check OK.
    Face volume ratio : minimum: 0.02250037 average: 0.9042536
    Face volume ratio check OK.
I attached a screenshot of the mesh, velocity- and temperature field, as well as the temperature log at the outlet.
Any comment is appreciated!
SeMar is offline   Reply With Quote
checkerboarding, chtmultiregionfoam, hanging nodes
Hexpress, move hanging nodes liyifei Fidelity CFD 6 October 12, 2015 22:08
Best way to handle hanging nodes in Fluent for LES? flotus1 FLUENT 4 December 16, 2013 04:32
[ICEM] Fix hanging nodes in 2D structure mesh after using block refinement Tedsjo ANSYS Meshing & Geometry 0 December 12, 2013 08:44
hanging boundary nodes aman Main CFD Forum 0 October 18, 2005 11:12
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
