April 19, 2018, 06:14 |
Steady-State solidDisplacementFoam
Juan Blanco
Rep Power: 9 |
I ran the tutorial plateHole with solidDisplacementFoam but I modified the initial conditions and set the traction boundary condition for displacement to zero, i.e. no forces acting on the plate. Also, I turned on the thermal stresses calculations with a constant initial temperature with adiabatic boundary conditions. From displacement equations I would expect that with a zero gradient temperature field the displacement will drop to zero, it did not (see figures attached). I analyzed the thermal gradient (I attach the figure) and, even though it is really small (~1e-13), it seems that affects the result from the displacement calculation. To test this, I turned off the thermal stress calculation and without the thermal term in the diplacement equation I do obtain a zero displacement field. I need to run a transient coupled to this which will add a source term to the energy equation that eventually fades away so I will eventually arrive to the problem state before. To sum up, the problem is that when approaching the stationary an incredibly small gradient modifies appreciably the displacement field. Observations: *Increasing outer loops and/or increasing number of energy equation solving steps did not work out. *A steady-state ddt scheme has problems with the energy equation, floating point sends an error. Thank you for your time. If anybody knows a solution it will be welcomed. |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
The difference between steady state and transient | JuPa | CFX | 36 | December 9, 2019 23:50 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
