Vapor fraction in chtMultiRegionFoam
Old   April 19, 2018, 05:28
Default Vapor fraction in chtMultiRegionFoam
MABH
MABH is on a distinguished road
How can I add a vapor fraction in the chtMultiRegionFoam?
Is for implementing a phase change simulation using that solver.
MABH is offline   Reply With Quote
Old   August 12, 2020, 23:34
wanghongjie
wanghongjie is on a distinguished road
Have a method?
wanghongjie is offline   Reply With Quote
Old   August 14, 2020, 20:32
Joachim Herb
jherb is on a distinguished road
In the ESI development line of OpenFOAM (openfoam.com) there is the solver chtMultiRegionTwoPhaseEulerFoam which can do what you want. See https://www.openfoam.com/releases/op...nd-physics.php
jherb is offline   Reply With Quote
Old   August 15, 2020, 00:07
wanghongjie
Thank you for your reply. My two-phase model is based on interCondensatingEvaporatingFoam, which is quite different in writing from TwoPhaseEulerFoam. So I want to implant interCondensatingEvaporatingFoam into chtMultiRegionFoam. Do you think it is feasible? I have been in contact with openfoam for a few months, and many things are not very clear. Thank you for your guidance.
Old   August 15, 2020, 19:45
Joachim Herb
There are two "challenges":
The first one is to get a new solver based on chtMultiRegionFoam. There you have to replace the solver in the fluid folder with your base solve (interCondensatingEvaporatingFoam). This is just "programming", but a a lot.
The second one is you have to find new boundary conditions for the wall where you model what happens physically there. Boiling/condensation? Then you have to implement it. If you look at the solver of ESI and the corresponding wall modelling, you can see, this is even more work. How much time do you have? Do you have help by co-workers? This sounds more like a at least one PhD thesis than e. g. a master thesis.
Old   August 16, 2020, 04:04
wanghongjie
Thank you for your reply. By consulting online information, I am currently modifying the fsiFoam in extend-4.0, but still face great challenges. For example, changing the single phase of the liquid zone to two phases, introducing temperature, etc. Yes, I am currently at the master's level and the program is part of the master's thesis.
Old   August 17, 2020, 11:48
wanghongjie
I am modifying the chtMultiRegionFoam with interCondensatingEvaporatingFoam, some problem happen in the createFluidFields.H. I cannot declare thermoFluid correctly, may you have an answer? Thanks!
Info<< "*** Reading fluid mesh thermophysical properties for region "
<< fluidRegions[i].name() << nl << endl;
Info<< " Adding to thermoFluid\n" << endl;
thermoFluid.set(i, twoPhaseMixtureEThermo::New(UFluid[i],phiFluid[i]);
./fluid/createFluidFields.H: In function ‘int main(int, char**)’:
./fluid/createFluidFields.H:50:48: error: reference to ‘New’ is ambiguous
50 | thermoFluid.set(i, twoPhaseMixtureEThermo::New(UFluid[i],phiFluid[i]);
phase change, vapor fraction
heat transfer, multiple regions, chtMultiRegionFoam? Ohlzen-Wendy OpenFOAM Pre-Processing 13 February 8, 2022 08:17
Error in thermophysical properties (chtMultiRegionFoam) mukut OpenFOAM Pre-Processing 28 November 23, 2021 07:34
chtMultiRegionFoam connection between solid and fluid region of heat exchanger ahab OpenFOAM 1 December 18, 2019 01:37
Simulation of a sample in a furnace w/ chtMultiRegionFoam sergimart7 OpenFOAM Running, Solving & CFD 7 August 12, 2015 07:48
FOAM FATAL IO ERROR for chtMultiRegionFoam xiaoyoyo OpenFOAM Running, Solving & CFD 0 May 8, 2012 17:49
