Odd behaviour in circuitBoardCooling
Old   April 18, 2018, 16:34
Default Odd behaviour in circuitBoardCooling
sturgeon is on a distinguished road
If I run the circuitBoardCooling tutorial case with buoyantSimpleFoam, entirely unmodified, except for removing the thermal baffles, the converged result looks like this:
So there's an odd vertical velocity at the top and bottom of the inlet. There's also slight checkerboarding, as you can see from this plot of Uy versus y axis from just inside the inlet:
Does anyone know why this is? I assume it's to do with the inlet, which is a consistent fixed velocity, encountering the noslip walls, where the converged solution is not going to be a consistent internal field of that fixed velocity. But I can't figure out how to fix it after searching online a lot. Any insight is greatly appreciated
Thanks
sturgeon is offline   Reply With Quote
Old   April 19, 2018, 01:45
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
It would be helpful if you'd posted your case or at least the file(s) you changed. You made some kind of error, of course. But without knowing your case, nobody can guess at which detail.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   April 19, 2018, 07:22
Sorry, I thought I was clear. This is literally an exact copy of the circuitBoardCooling tutorial from buoyantSimpleFoam, except I never executed the command to add the thermal baffles. I didn't change anything else. If you take the circuitBoardCooling case, rename the 0.orig to 0, execute blockMesh and buoyantSimpleFoam, you will have this case.
Old   April 26, 2018, 09:22
Sorry to bump but does anyone have any information on this? It's plaguing some other cases of mine. Cheers
Odd behaviour of pressure/velocity at the wall of a moving tube t.m OpenFOAM Running, Solving & CFD 0 May 30, 2013 09:20
Odd residual behaviour for Two Layer K Epsilon dvcauwe Main CFD Forum 1 March 7, 2012 06:47
extrudeMesh - odd behaviour grjmell OpenFOAM 0 September 20, 2011 09:41
Odd behaviour in wigleyHull in OF 2.0 msbealo OpenFOAM Running, Solving & CFD 0 July 16, 2011 06:53
Unstable behaviour after long period of stablility plunge11 FLUENT 1 April 6, 2011 10:15
