Surface roughness with dambreak question
Old   April 18, 2018, 11:24
Default Surface roughness with dambreak question
Jesse Cheung
kcc49 is on a distinguished road
Hello all,
I have been working on a dissertation which is on the topic of dam break and surface roughness relationship and currently, I am using the model base on the dambreakwithobstacle in tutorial.
For some reason no matter how I change the value of Ks and Cs in 0/nut, it has no effect on final result but I have no idea why.
the setup of the model file is uploaded to google drive: https://drive.google.com/open?id=10R...GKOwE0Az8OfBIf
If you guys have time would you mind take a look at whats wrong?
Many thanks!
Jesse
kcc49 is offline   Reply With Quote
Old   April 18, 2018, 11:27
Jesse Cheung
Originally Posted by kcc49 View Post
Hello all,
Many thanks!
Jesse
for some reason, the above link doesn't work this should be working
https://drive.google.com/open?id=10R...Q3GKOwE0Az8OfB
Old   April 18, 2018, 23:53
Taher Chegini
Taataa is on a distinguished road
Because your case is laminar! nut is turbulent viscosity if the case is laminar it doesn't calculate nut. Set it to RAS and pick a turbulence model such as SST or realizable.
Taataa is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
Surface Roughness Jochem OpenFOAM 2 July 6, 2011 07:17
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
effekt of surface roughness very small Ralf Schmidt FLUENT 0 December 7, 2007 06:46
