Addition of transport in one of the two phases - VoF
Old   April 16, 2018, 11:24
Default Addition of transport in one of the two phases - VoF
K
kuria is on a distinguished road
Hey everyone!
I am using interFoam solver for my simulation of species transport from the walls due to bubble rising.
I took the example case of bubble rising in a column and added a scalar transport equation :
solve
fvm::ddt(Y_K)
- v_K*fvm::laplacian(D_K, Y_K)
+ v_K*fvm::div(phi,Y_K)
As far as I understand interFoam solver, volume fraction of the phases is computed by a simple advection equation and the fluid properties like density and flow field in the whole domain is computed based on weighing of the fluid and gas fractions.
Due to this, when I run my equation for scalar transport, I end up solving it for the whole domain (both liquid and gas).
I also tried
solve
fvm::ddt(Y_K)
- v_K*fvm::laplacian(alpha1*D_K, Y_K)
But this also gives diffusion into the bubble.
The only way I could fix it was by forcing the solution to be zero in the bubble like:
solve
fvm::ddt(Y_K)
Y_K=Y_K*alpha1;
Has someone found a better way to address this problem?
kuria is offline   Reply With Quote
Old   May 25, 2019, 03:15
Niu
Z.Q. Niu is on a distinguished road
Hi Kurian, have you found the solution? Please see this post:interFoam with transport: add a transport equation to only one phase . I hope it may help you!
Z.Q. Niu is offline   Reply With Quote
species tranport, vof model
Does the VOF model calculte the heat transfer between the phases? wxf1037 FLUENT 3 June 28, 2015 03:47
multiphaseEulerFoam: PtrDictionary<phaseModel> phases_ of multiphasesystem fluid maybee OpenFOAM Programming & Development 9 January 27, 2014 07:24
ATTENTION!! Validty of Fluent's VOF?? ozgur Main CFD Forum 3 February 18, 2004 19:19
ATTENTION!! Validty of Fluent's VOF?? ozgur FLUENT 1 February 18, 2004 12:59
Moving mesh or VOF? Giovanni Main CFD Forum 16 September 24, 2001 09:25
