dynamic pressure in pimpleFoam
Old   April 13, 2018, 03:52
Default dynamic pressure in pimpleFoam
ashkan is on a distinguished road
Hi
I was wondering if it is possible to pass dynamic pressure in "forces" function in pimpleFoam rather than total pressure. The case I am interested is single phase with no gravity (so p_rgh is meaningless) and I am interested in calculating forces on a body. To be more precise, I want the "forces" function to calculate forces from pressure estimated "1/2*rho*U^2", where U would be the relative velocity of fluid and boundary patch.
The reason is that I am using this with oscillating flow in the domain and if I use total pressure, I get very wrong lift forces. I have already made the following thread but no comments yet
forces on body in oscillatory flow
I tried to calculate the dynamic pressure form the turbulence kinetic energy (pdyn = (2k/3)/(2I^2)*rho) and then F = sum( Pdyn*Area*n ) but that's also not correct.
I believe there should be much simpler way. So any comments are much appreciated.
Thanks
Ashkan
ashkan is offline   Reply With Quote
Old   April 13, 2018, 08:14
I have managed to solve my problem. I am not so sure if it was the best approach but I thought someone may find it useful. I basically, put a pressure probe along the line of the body but far away from it. Then I recorded that pressure during the simulation time. Finally, I extracted the surface mesh of the body and the pressure over it, for each element and at each time subtracted the probe pressure from its total pressure and integrated that over the body surface.
The final results matched the experimental data very well.
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 17:29
Setting up the pressure variation due to tornado in a duct(UDF)+animation guillaume1990 FLUENT 0 March 3, 2014 12:59
Dynamic pressure from the total pressure specified saisanthoshm88 CFX 1 August 9, 2012 07:13
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
