April 8, 2018, 05:41 |
the scheme of div(tau) in high De number
A. Min
Rep Power: 12 |
Hi
I'm using viscoelasticFluidFoam for a shedding flow. If I use upwind for div(tau) I will have 25% error in amplitude of oscillations. If I use URF the problem of amplitude will be solved, but I will have a big error in Strouhal number (period time)! And If I use any other scheme for div(tau) the solution will be diverged (without URF)! The divergence is stated in a special point and diffuses in all of the doamin: this is the grid in this point: I don't know what I should do. |
divergence, scheme, viscoelasticfluidfoam |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 22:00 |
decomposePar no field transfert | Jeanp | OpenFOAM Pre-Processing | 3 | June 18, 2022 13:01 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 04:58 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 16:03 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
