Using reactingFoam from SandiaD template for H2 O2 non premixed combustion
Old   April 7, 2018, 13:14
Default Using reactingFoam from SandiaD template for H2 O2 non premixed combustion
Mateus Grassano Lattari
MateusLatt is on a distinguished road
Hello everyone,
I am trying to simulate a H2-02 combustion using some modifications in the SadiaD template. After exporting a geometry of a liquid rocket combustion chamber and meshing it (using blockMesh followed by snappyhexmesh). I was able to obtain the H2 and O2 flow and a simple mixing of the species.After 50 interactions of the program I have programmed the chemistry "on" in the constant folder, but no chemical reaction or changing in the temperature occurred.
I read in this forum that the combustion was supposed to be ignited using the setFieldsDict, i understood that there was a "box" with the boundaries conditions that starts the flame. But I am not able to set the position of this box in my geometry to initiate the combustion. Does anyone ever had a similar problem?Or i should study more materials to understand better this simulation, and if I do, does anyone could send it to me?
Regards,
Mateus
MateusLatt is offline   Reply With Quote
Old   April 9, 2018, 17:53
Daniel Norton
Dano62 is on a distinguished road
The box defines the domain of any special regions. I would assume that you would specify a very high temperature within this box to initiate combustion. You should be able set the temperature similar to this, then run setFields. https://github.com/OpenFOAM/OpenFOAM.../setFieldsDict
Dano62 is offline   Reply With Quote
Old   April 22, 2018, 21:57
Thanks for your answer. I am trying to set this box inside my combustion chamber. But how can i set the box position using those inputs:
box ( 0.04 0.04 -1.0 ) ( 0.06 0.06 1.0 );
Because I've modeled a .STL combustion chamber in Blender and used SnappyHexMesh to mesh it. I was trying to run set Fields and to locate the Box position using ParaFoam right after running setFields. Is there a more efficient way?
Old   April 23, 2018, 00:24
Ok, I did it. I did some small changes to setFieldsDict box while paraFoam was opened and i could set the box to the position that i needed by running SetFields multiple times.
It was like
(xi,yi,zi) (xf,yf,zf), where xi= x initial
where xf= x final
And xf-xi is the x dimension of a box in the x axis.The same for the other directions.
Other problem was that I had fixed the temperature of the wall, so the box could't change the temperature of the combustion chamber, the solution was to set: type zerogradient.
reactingfoam, sandiad
Modelling of premixed combustion in a burner rig ThomasS FLUENT 12 September 7, 2018 14:07
How to switch off combustion and reaction in reactingFoam shenzhou1987 OpenFOAM Running, Solving & CFD 16 October 26, 2017 16:31
ReactingFoam error for premixed combustion yesudiannaveen OpenFOAM Running, Solving & CFD 0 February 11, 2016 02:29
How to model premixed combustion using partially premixed combustion model in Fluent? sab10012 FLUENT 0 October 6, 2015 02:18
Partially Premixed Combustion - Direct Fired Boiler oknus FLUENT 0 April 10, 2012 11:52
