Finding the snGrad for all the faces of all cells.
Old   April 7, 2018, 03:19
Default Finding the snGrad for all the faces of all cells.
Harris Daniel S
Harris_Daniel is on a distinguished road
I am using OpenFOAM-v1612+ and modified InterFoam solver by introducing the Fourier's Heat Equation from laplacian Foam. Now I need to calculate the snGrad for all the faces of all the cells by looping over the cells and faces. I wrote a code but there seems to be a problem with it.
I wrote the following code:
forAll(C.internalField(), cellI)
        const labelList& faces = mesh.cells()[cellI];
        double Tin = Tf.ref()[cellI];
        scalarField Ti = Tin.sndGrad();
        forAll(faces,I)
           const scalar Tsngrad(T.ref()[faces[I]].snGrad());
And got the following a error message:
error: request for member ‘sndGrad’ in ‘Tin’, which is of non-class type ‘double’
error: request for member ‘snGrad’ in ‘(& T.Foam::GeometricField<Type, PatchField, GeoMesh>::ref<double, Foam::fvPatchField, Foam::volMesh>())->Foam:imensionedField<double, Foam::volMesh>::<anonymous>.Foam::Field<double>::< anonymous>.Foam::List<double>::<anonymous>.Foam::U List<T>:perator[]<double>(((int)(& faces)->Foam::List<int>::<anonymous>.Foam::UList<T>:per ator[]<int>(CellI)))’, which is of non-class type ‘double’
const scalar Tsngrad(T.ref()[faces[CellI]].snGrad());
Please help me clear this error. I have had a look through the snGradScheme.C file but in vain.
What does sndGrad scheme return? It says that it return the sndGrad for a given cell field. Can anyone elaborate on this.
More importantly what should be the inputs to a snGrad and sndGrad scheme(I am asking about the data types).
Regards,
S. Harris Daniel.
Harris_Daniel is offline   Reply With Quote
looping over the cells, sndgrad, sngrad
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 02:37
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 09:26
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 06:29
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
