April 3, 2018, 06:46 |
actuatordisk implemetation
Daniela
Dear Foamers,
I am currently trying to simulate a propeller within a strout. I am trying to show what influence the holder of the strout has on the force on the surface of the strout. Now my Problem: I implemented the propeller with the actuatordisk. I used parameters of experiments from that propeller named KT for ct and calculated the cp with the given P. KT can also be calcualted with: ct=T/(rho*n^2*D^4) and cp=P/(rho*n^3*D^5) Now the Results aren’t the way I expected them to be. The mean velocity of the flow is 2m/s and the disk accelerates the flow to values like 900 m/s (until the calcualtion is aborting). I know the code of the actuatordisk. But I don’t see how I calculate a when I don’t know if my values for ct and cp are right (and obviously they are not, since the calcualtion wouldn’t crash if they where). I will attach my fvOptions. I am sure the Problem is an error in my setup, but I am helpless to find it right now. Thanks in advance! Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object fvOptions; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // disk1 { type actuationDiskSource; active on; actuationDiskSourceCoeffs { fields (U); selectionMode cellSet; cellSet actuationDisk1; diskDir (1 0 0); Cp 0.3273; Ct 0.2728; diskArea 0.036; upstreamPoint (0 0 0); } } With kind regards, Daniela |
April 5, 2018, 15:45 |
Daniela
My suggestion is, I need different coefficients, since most explanations are for wind turbines. So normally the disk ist for taking energy out of the stream, while I want to induce energy to it. Unfortunately I don't find any explanations about this case.
I found that if I use the thrust loading coefficient I get (more) plausible results. But I can't explain it nor can I be sure it is the right way, when I don't find any source to look the topic up. Additionally I calculated the Thrust with the equation in the source code but don't get a result near the measured. Code:
Constant values for momentum source for actuation disk \f[ T = 2 \rho A U_{o}^2 a (1-a) \f] and \f[ U_1 = (1 - a)U_{o} \f] where: \vartable A | disk area U_o | upstream velocity a | 1 - Cp/Ct U_1 | velocity at the disk \endvartable Thanks again in advance and best regards, Daniela |
February 9, 2022, 04:48 |
actuator disc on ship
Sachin
Rep Power: 12 |
I saw your post on one of the forums related to actuator disc on ship. I am also stuck with a same problem. What is the value of Cp and Ct to be used. I can get the values of J,Kt,etta from propeller openwater test. Thanks Sachin |
February 9, 2022, 06:17 |
#4 | |
Kabir Shariff
Rep Power: 10 |
1. You can modify the definition of Ct in the actuator disc model to suit your equation. here 2. To use the actuator disc as a propeller, the sink should be 'false' to create a production thrust force. |
February 9, 2022, 07:12 |
Sachin
Rep Power: 12 |
Could you share a sample case if you happen to have one?
February 11, 2022, 01:36 |
#6 | |
Sachin
Rep Power: 12 |
February 11, 2022, 04:50 |
#7 | |
Kabir Shariff
Rep Power: 10 |
You have to get your hands a bit dirty to customize the equation. here are some steps: 1. Copy the actuatorDisk folder and rename it to say myActuatorDisk. 2. Modify all the actuatorDisk keywords to myActuatorDisk. 3. Compile the new actuator disk and run it to ensure you have the same result. NB: the previous actuator disk should remain original. so as not to mess up the code in the future. 4. If the new myActuatordisk is compiled successfully, run a test simulation to ensure you have same results. ( remember to change the keyword also in the fvOptions to myActuatordisk) 5. If all is ok, then you can go to the file here in your modified folder. 6. At first you can modify the code like this Code:
const scalar a = your calculated ct value;//1.0 - Cp/Ct; const scalar T = 0.5*rhoRef*diskArea_*magSqr(Uref & diskDir_)*a*; this according to your equation of thrust force //2.0*rhoRef*diskArea_*magSqr(Uref & diskDir_)*a*(1 - a); 8. With this modification, the Cp and Ct defined in the fvOptions are not considered during calculation since you change the equation in the source term. 9. Ensure the sink is 'false' to apply the disc as production, not extraction of energy 10. If all is ok, then you can edit the code to control the parameters Kt and Kq directly in fvOptions. 11. Goodluck, Openfoam is hands-on. |
Please help with implemetation of boundaries conditions for flow in a pipe | Michail | Main CFD Forum | 5 | July 12, 2012 06:47 |
Please help with momentum sources and actuatordisk | Nikolas | FLUENT | 1 | June 16, 2010 07:54 |
