Rep Power: 9 ![]() |
When I have a wall I typically use "noSlip" as boundary condition for the velocity U also when dealing with turbulent flow.
At the same time I use turbulence models with wallfunctions for the turbulence variables. It does not seem like there are specific wallFunctions for the velocity. Is the answer that in practice the velocity U is indirectly determined by wallfunctions through the turbulence variables (that is modelled with wallFunctions)? |
Robert
Rep Power: 12 ![]() |
To my knowledge, the typical expectation is that your velocity is Zero (0 0 0) at the wall. That is why you use a noSlip, or fixedValue (0 0 0) which does the same, boundary condition.
#3 | |
So one has no slip at the wall, but do you know what one have between the wall and the 1st cell for U when one use e.g. nutUSpalding for nut at the wall? |
Uwe Pilz
Rep Power: 15 ![]() |
There is no wall function for U because the flow is the result of your calculation. If you use only p and U, then you don't have any additional model for turbulence. If you use such a model (e.g. k-epsilon) this model influences the flow. It does that in a different way in the near of walls.
The wall function is not a property of the flow but a property of the model of turbulence.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
#5 | |
Thanks! |
wallfunctions |
k-OmegaSST: Wallfunctions or not? | kaaja | OpenFOAM Running, Solving & CFD | 1 | March 6, 2018 10:18 |
yPlus and wallfunctions in rotating walls | Yuby | OpenFOAM Running, Solving & CFD | 1 | April 20, 2015 11:32 |
Scalable wallFunctions openFOAM? | Hekky | OpenFOAM Running, Solving & CFD | 0 | November 5, 2013 08:00 |
problem with wallFunctions (kEpsilon model) | dinonettis | OpenFOAM | 12 | April 22, 2010 21:37 |
decompose with wallfunctions | linnemann | OpenFOAM Running, Solving & CFD | 4 | October 16, 2009 06:41 |
