Anisotropic (~2) divergence/Courant number explosion |
April 2, 2018, 00:46 |
Dear all,
I'm sure this is an easy thing as I'm new to OpenFOAM. I'm trying to run a simple laminar flow in a 2.5x0.41x0.41 channel with x-inlet velocity = 1 and nu = 1. Everything works fine with an isotropic mesh, but when I increase the anisotropy ratio to 2 or beyond (meshCheck is ok execpt for Max aspect ratio = 2.0098 OK, which should be fine I think) the Courant number steadily increases even though the linear solvers converge fine. I'm using icoFoam ddtScheme Euler with a small time step 0.005 (and potential flow initialization), and have three boundary patches: Code:
1: wall - U: type fixedValue; value uniform (0 0 0); p: type zeroGradient; 2(x==0): patch - U: type fixedValue; value uniform (1 0 0); p: type zeroGradient; 3(x==2.5): patch - U: type zeroGradient; p: type fixedValue; value uniform 0; Code:
... Time = 0.02 Courant Number mean: 0.396073 max: 0.595328 DILUPBiCG: Solving for Ux, Initial residual = 0.710458, Final residual = 6.05412e-009, No Iterations 29 DILUPBiCG: Solving for Uy, Initial residual = 0.555298, Final residual = 8.24426e-009, No Iterations 27 DILUPBiCG: Solving for Uz, Initial residual = 0.555298, Final residual = 8.24421e-009, No Iterations 27 GAMG: Solving for p, Initial residual = 0.146766, Final residual = 8.4081e-009, No Iterations 24 GAMG: Solving for p, Initial residual = 3.12959e-010, Final residual = 3.12959e-010, No Iterations 0 GAMG: Solving for p, Initial residual = 3.12959e-010, Final residual = 3.12959e-010, No Iterations 0 time step continuity errors : sum local = 4.908e-010, global = 1.35872e-010, cumulative = 3.72047e-010 GAMG: Solving for p, Initial residual = 0.00478919, Final residual = 9.99079e-009, No Iterations 19 GAMG: Solving for p, Initial residual = 5.2169e-007, Final residual = 7.70071e-009, No Iterations 6 GAMG: Solving for p, Initial residual = 7.70139e-009, Final residual = 7.70139e-009, No Iterations 0 time step continuity errors : sum local = 2.30206e-010, global = -6.38586e-011, cumulative = 3.08189e-010 ExecutionTime = 8.047 s ClockTime = 8 s Time = 0.025 Courant Number mean: 0.469957 max: 1.39104 DILUPBiCG: Solving for Ux, Initial residual = 0.338095, Final residual = 6.63966e-009, No Iterations 28 DILUPBiCG: Solving for Uy, Initial residual = 0.381617, Final residual = 7.22101e-009, No Iterations 27 DILUPBiCG: Solving for Uz, Initial residual = 0.381617, Final residual = 7.221e-009, No Iterations 27 GAMG: Solving for p, Initial residual = 0.285914, Final residual = 6.1955e-009, No Iterations 25 GAMG: Solving for p, Initial residual = 1.60704e-010, Final residual = 1.60704e-010, No Iterations 0 GAMG: Solving for p, Initial residual = 1.60704e-010, Final residual = 1.60704e-010, No Iterations 0 time step continuity errors : sum local = 2.46742e-010, global = -6.86928e-011, cumulative = 2.39496e-010 GAMG: Solving for p, Initial residual = 0.00646772, Final residual = 5.10226e-009, No Iterations 20 GAMG: Solving for p, Initial residual = 1.52933e-007, Final residual = 9.2095e-009, No Iterations 4 GAMG: Solving for p, Initial residual = 9.20973e-009, Final residual = 9.20973e-009, No Iterations 0 time step continuity errors : sum local = 4.68844e-010, global = 1.30753e-010, cumulative = 3.70249e-010 ExecutionTime = 9.923 s ClockTime = 10 s Time = 0.03 Courant Number mean: 0.399864 max: 0.877514 DILUPBiCG: Solving for Ux, Initial residual = 0.553235, Final residual = 7.50458e-009, No Iterations 29 DILUPBiCG: Solving for Uy, Initial residual = 0.664806, Final residual = 6.56398e-009, No Iterations 28 DILUPBiCG: Solving for Uz, Initial residual = 0.664806, Final residual = 6.56398e-009, No Iterations 28 GAMG: Solving for p, Initial residual = 0.240677, Final residual = 8.57317e-009, No Iterations 24 GAMG: Solving for p, Initial residual = 3.59447e-010, Final residual = 3.59447e-010, No Iterations 0 GAMG: Solving for p, Initial residual = 3.59447e-010, Final residual = 3.59447e-010, No Iterations 0 time step continuity errors : sum local = 5.52764e-010, global = 1.5542e-010, cumulative = 5.25669e-010 GAMG: Solving for p, Initial residual = 0.00873356, Final residual = 5.62807e-009, No Iterations 20 GAMG: Solving for p, Initial residual = 2.56358e-007, Final residual = 7.65837e-009, No Iterations 5 GAMG: Solving for p, Initial residual = 7.6587e-009, Final residual = 7.6587e-009, No Iterations 0 time step continuity errors : sum local = 2.56423e-010, global = -7.21304e-011, cumulative = 4.53539e-010 ExecutionTime = 11.86 s ClockTime = 12 s Time = 0.035 Courant Number mean: 0.462337 max: 1.70965 Time = 0.04 Courant Number mean: 0.406624 max: 1.26753 Time = 0.045 Courant Number mean: 0.470408 max: 2.2144 ... |
April 2, 2018, 02:28 |
Uwe Pilz
Rep Power: 15 |
If you have elements with very different length of the sides, the Courant number increases, because it roughly gives the way the fluid moves in one time step, measured in element sizes. If one side is very small, then the element size like velocity gets very high.
I think there exist reasons for this mesh. I recommend either reducing the time step for keeping the Co number low or thinking about your meshing strategy: Is ist really necessary to that extend?
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
anisotropic mesh, courant, divergence, openfoam |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 10:12 |
ERROR #001100279 has occurred in subroutine ErrAction. | smnaryal | CFX | 11 | December 20, 2017 17:32 |
[foam-extend.org] Foam-extend-3.1 on RHEL: mesh problem | lxwd | OpenFOAM Installation | 4 | March 25, 2017 17:10 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 15:53 |
Stable boundaries | marcoymarc | CFX | 33 | March 13, 2013 07:39 |
