multiphase-multiparticle
Old   March 31, 2018, 17:20
Default multiphase-multiparticle
Gustavo Cordoba
gcordobaguerrero is on a distinguished road
Hello all,
I need to model a multiphase thermocouled flow, which have at least two particle sizes and hot air, all of them inmersed on ambient air.
I did a successful attemp using the two phase tutorial fluidization case. However, that model is limited to just one particle size.
I would like to know if:
1. There is a multiphase-multiparticle solver available
2.- How can modify the reactingTwoPhaseEulerFoam/fluidized solver to be able to account for at least two particle sizes?
Thanks,
Gustavo Cordoba
gcordobaguerrero is offline   Reply With Quote
Old   April 6, 2018, 13:26
Anurag
anuragm is on a distinguished road
Hello Gustavo
1. Are the two particle sizes changing in time?
2. Is the volume fraction of the particles of each size changing in time?
anuragm is offline   Reply With Quote
Old   April 6, 2018, 18:14
Default volumefraction of particles and particle sizes
Gustavo Cordoba
Hi, thanks for your answer.
Your questions:
No, neither the sizes nor the total amount of particles change in space and time (of course, if erosion/deposition of particles is not taken into account)
Yes, there is a change of such a volume fractions in space and time.
Thanks again,
Gustavo
Old   April 9, 2018, 07:42
Anurag
Hi Gustavo,
I would suggest using twoPhaseEulerFoam/multiphaseEulerFoam (or a derivative solver) and create two phases with different diameters associated with them. Both these solvers have particle diameters built-in as well as certain models for drag, etc. Of course, I am assuming that you are fine with an Eulerian description of your system.
This means there is no transport in the particle property space & and the problem is simple to handle. So you will not have to use PBE or IATE in your solver.
This can be taken care of using the approach of defining two phases with different diameters. Their volume fractions can also change based on the model you choose.
fluidized beds, multiparticle, multiphase
Multiphase Flow Simulation AS_Aero STAR-CCM+ 1 March 19, 2018 00:14
How to simulate the eulerian multiphase model about particle jhlee9622 STAR-CCM+ 2 November 24, 2016 12:37
about Lagrangian Multiphase Simulation jhlee9622 STAR-CCM+ 0 March 18, 2015 02:38
Low Mach Number Compressible Multiphase Flows DarrenC CFX 10 May 26, 2014 09:52
multiphase multicomponent physics ckleanth CFX 3 June 4, 2009 21:15
