Romit
Rep Power: 0 ![]() |
Hello everyone, I am a beginner to OpenFOAM and RANS in general and was having some troubles with convergence with my case. My files are attached in the archive.
I see that my residuals converge nicely for the first one thousand odd iterations (you can look at the plot I have attached too) but around iteration 2000 pressure residuals start growing. I feel like it may be an issue with numerics as explored here: SimpleFoam convergence problems and I am trying different combinations of schemes. Otherwise I am puzzled and would appreciate any suggestions. Thanks P.S. Case files attached (without the mesh but I can mail that to you if needed). I have also attached a checkMesh output. Edit: Grammar ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Some more information I am using a k-omega-sst model with yplus values around 5-10 (I know this is a bit high for low Re models) but they are in the vicinity of walls that are not really important. Could this be an issue? Last edited by CFDBro; March 29, 2018 at 13:34. Reason: Some more information |
numerics, simplefoam not converged |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
