Changing the Sutherland coefficients during simulation
Old   March 22, 2018, 04:08
Default Changing the Sutherland coefficients during simulation
Teun Verstraaten
slugger is on a distinguished road
Hi everyone.
I am running a simulation of air being pushed at high speed through a narrow opening. I use a high pressure at the inlet and ambient pressure at the outlet to drive the flow. To ensure that the simulation does not immediately crash due to poor initial pressure and velocity conditions, I start the simulation with a very high viscosity. I am using the Sutherland transport model with
transport
Pr 0.7;
As 1.4792e-02; // really should be 1.4792e-06
Ts 113;
As you can see, the coefficient As is 10^4 times as large as it should be, and this ensures that the simulation behaves properly.
I would like to be able to change the coefficient As as the simulation runs. I know this is possible for the quantities at the boundaries, I am already doing this for the pressure at the inlet, which I slowly increase from 1bar to 4.5bar, but I cannot seem to find any info on how I should dynamically change the thermo properties.
Thanks,
Teun
slugger is offline   Reply With Quote
sutherland, viscosity model
restarting paused transient simulation using reactingFoam JMDag2004 OpenFOAM Running, Solving & CFD 1 August 10, 2015 11:15
Use homogeneous results as the initial guess for an inhomogeneous simulation JuPa CFX 5 December 26, 2014 14:44
Boundary condition setting regarding turbine simulation using CFX Lacerlacer CFX 11 March 12, 2012 10:32
Replacing mesh while running a simulation akultane CFX 1 November 15, 2009 14:46
phase changing simulation David Liu Main CFD Forum 3 October 25, 2004 02:43
